Question about Samsung SGH-e317
Cellular phone doesnt recognize SIM after it got wet
My cellular phone keeps on displaying `insert sim` even if the sim card is in place. this happens after the phone got wet. i tried to dry it and check if it is still working. the power turns on but the sim card problem persist. pls help. many thanks!
  • Anonymous Mar 12, 2014
    When turned on screen displays No Sim card. Emergency calls only, problem is the sim card is in place, need help
  • Anonymous Mar 30, 2014
    chatr sim card was working but stopped after 2 days but all other sim cards work
  • 74 Answers
Dear it happen when mostly connection of sim module is cut of check the connection.
Posted on Mar 26, 2007
My 6300nokia mobile phone was not recognizing sim card
Hi, have you tried using different Sim Card to check if the issue is related to Sim Card.? These issues happen due to Sim Card chip has damaged inside. If the same error displayed even after using working Sim Card, try to insert properly or the Phone's Sim Card Slot pins have not conducting properly to the Sim Card, in this case Service might be required to the Cellphone.
Jul 23, 2011 | Nokia 6300 Cellular Phone
It comes up with Insert SIM Emergency? What is SIM?
A SIM card or Subscriber Identity Module is a portable memory chip used in some models of cellular telephones. The SIM card makes it easy to switch to a new phone by simply sliding the SIM out of the old phone and into the new one. The SIM holds personal identity information, cell phone number, phone book, text messages and other data. It can be thought of as a mini hard disk that automatically activates the phone into which it is inserted.
A SIM card can come in very handy. For example, let's say your phone runs out of battery power at a friend's house. Assuming you both have SIM-based phones, you can remove the SIM card from your phone and slide it into your friend's phone to make your call. Your carrier processes the call as if it were made from your phone, so it won't count against your friend's minutes.
If you upgrade your phone there's no hassle involved. The SIM card is all you need. Just slide it into the new phone and you're good to go. You can even keep multiple phones for different purposes. An inexpensive phone in the glove compartment, for example, for emergency use, one phone for work and another for home. Just slide your SIM card into whatever phone you wish to use.
High-end cell phones can be very attractive and somewhat pricey. If you invest in an expensive phone you might want to keep it awhile. Using a SIM card, it is even possible to switch carriers and continue to use the same phone. The new carrier will simply issue you their own SIM card. The phone must be unlocked, however, and operate on the new carrier's frequency or band.
When it's not inserted properly, it displays insert .You will need to insert the sim card properly so that the message won't come up again..
Mar 11, 2011 | LG Vu CU920 Cellular Phone
Even after i reboot it it keeps saying invalid sim card
Remove your sim card, wipe it with a smooth dry cloth and insert it again.
If this doesnt work, contact your network provider and they will help you.
Jan 02, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
SIM Card not recognized.
the nokia 3110 is not a powerful device it will surely not recognise the sim because it contained the data which might be copied to the phone memory as well as the sim card so during the sim after being wet & dry was certainly not going to be recognized by the cell as its data was corrupted
May 24, 2009 | Nokia 3110 Cellular Phone
Samsung G600 - phone asks for sim card but doesnt work when inser
when phones get wet they start to rust from the inside, unfourtunaly this is a long prosses and can take a few months but usually if the phone has got very wet they will not work propley again. they may work temperally but eventually it will probably be completly usless. in future if u wet a phone try drying it immediatly with a hairdryer, inside the battery bit too, this may help the water inside the phone not to cause rusting. sorry about your phone.
May 14, 2009 | Samsung SGH-G600 Cellular Phone
Sim ic
hi im josh in cebu phils.it is very simple friend if your phone doesnt recognize the sim. clean your sim card reader with a brush slowly friend. then be sure the connections to the sim firmly contact because lost contact may gve such problem. good luck. hope i helped you.vote me so that i wl know if i helped you so.thnks.
Feb 23, 2009 | Nokia 1600 Cellular Phone
Insert SIM Card
make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
Mar 27, 2008 | Nokia 6270 Cellular Phone
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
SE K750i displaying 'insert sim' even though sim is inside.
This problem is due to your phone's sim card IC malfunctioning. It may get damaged due to phone dropping gently into rough surface and its crystal structure may break due to it. for any queries mail to mahesh_vr@yahoo.com
Sep 01, 2007 | Sony Ericsson K750i Cellular Phone
Samsung SGH-e317 Logo
129 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
