Question about Reddy Heater-30-55,000 BTU Variable
Won't stay lit..
I have a Reddy 75-125,00 forced air/propane. It ignites and as long as I hold the igniter in its fine, but it won't stay lit.....
  • 2 more comments
  • ndb7 Dec 16, 2008
    Got the exact same problem on a 35k BTU unit... it won't stay lit unless I hold down the ignitor button continuously
  • m61magnum Dec 20, 2008
    Heat stays lite aslong as Hold the botton in. I am thinking about by passing the sensor against the back plate. Also , my thermo coupler is not mounted solid. It can be pushed in and pulled out. I looked at a new model and that coupler is solid. I am going to try to find parts.
  • Anonymous Jan 02, 2009
    i have a reddy heater propane fired, it will stay lit as long as i hold the button , but as soon as i release the button the fire goes out. What could be the problem/
  • hallstrom Jan 06, 2009
    I have a Reddy heater 125 t that is almost new and has been in the shop for warranty 3 time and again recently for the ignition control assembly burning out. I maybe have 5 hours of use on this heater. Any help
I contacted ReddyParts.com and talked with their support department (866-883-9312). They instantly stated "your thermal coupler is bad". They had 1 in stock for 19.99 + shipping. I ordered it and plan to have it installed and tested by next weekend. The model I have is Reddy Heater Propane 35k to 55k (RLP55V).
Posted on Dec 20, 2008
I have a PRO100 Reddy Heater would not stay lit when you release the ignite button. I replaced the thermocouple and it did nothing. What else could be the problem besides the valve?
I had the same problem. Heater was propane with a long hose for movement.
I put the heater on my garage work bench and the thermocouple tested okay.
Tried to restart and it ran like a champ. Reassembled bottom panel, retested great.
When I set it on the floor, it went out! Hmmmm.
Restarted back on the benck. Great. No good on floor....Very cold (28 F) in the garage.
Think the propane might be going liquid in the hose...when heater hose has a "drip loop"
it works fine.
Maybe this is nuts, but it works keeping the heater up a bit on a STABLE surface.
Jim
Dec 17, 2010 | Reddy Heater RLP100 Portable Forced Air...
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
The gas does not light
get a new unit dont play with propane it goes bang!!
Oct 31, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heater will not stay lit
Leave automatic button depressed for 30 seconds after flame ignites.
Jan 14, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddyheat rlp 100 will not stay lit, strong gas smell.
I had the same problem with my Reddy Heater PRO 100. It is the 20Lb bottle causing your problem.
I Put a 100LB bottle on and ended my problems.
Dec 31, 2008 | Reddy Heater RLP100 Portable Forced Air...
Forced air propane heater won't stay lit
two items come into play here - 1) the hot surface cutout and 2) the flame detect Cd cell. Check alignment of the Cd cell or just replace it. The hot surface cutout has two terminals that plug into the two tabs on the millivolt generator.
Feb 06, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Won't stay lit
call 800 397 7553 with model number
Dec 21, 2006 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater-30-55,000 BTU Variable Logo
353 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
