Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My u3 is gone and i want to use it.
I think i some how deleted u3 off of my 2gb flash drive. how do i get it back.
  • destrut Dec 16, 2008
    u3 is gone
  • 126 Answers
My 2gb sandisk cruzer pen drive showing only 19 mb i formate it but its same plz help me to get full 2gb
I think, damaged flash drive Firmware. To fix the firmware or firmware update, use the U3 Lauchpad. U3 Lauchpad, can be used to save data, repair the firmware, and firmware updates.
If you use the operating system
Win XP, download the file from here SunDisk Support
Win 7, download the file from here SunDisk Support
hope it helps
Sep 10, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My SanDisk 1gb flash drive says i only have 1 try left at trying to unlock it. I didn't even know i had locked it. Can you please Help?
This will get the drive back, but you WILL lose the data. If you need the data. I do not know the answer. Repost your question to go to Sandisk site below
'.............U3 smart drives come preinstalled with the U3 Launchpad which emulates the Windows OS start menu, and controls program installation and hence facilitate the portability of software. However, if you would like to use the USB flash drive or memory key as a pure normal USB mass storage device, or you don't use operating system that U3 supports (i.e Windows XP and Windows 2000 operating systems), or you simply feel that U3 Launchpad and applications have bugs such as unable to eject due to locked files in use, consent on privacy and automatic installation of U3 software and pop-up etc, you can uninstall and remove the U3 Launchpad from the USB storage device.
To remove and delete the U3 Launchpad, you need to download U3 Launchpad uninstallers or U3 Launchpad Removal Tool that remove the U3 Launchpad and re-configure the USB drive to be a single mass storage USB drive. Currently, U3 Launchpad uninstallers are only available for and must be run on Windows XP or Windows 2000 machine. When uninstalling, the U3 smart drives USB device has to be plugged in with U3 Launchpad running.
U3 Launchpad Removal Tool for SanDisk USB U3 devices can be downloaded here, http://u3.sandisk.com/
WARNING: U3 Launchpad removal is irreversible. You won't be able to install U3 again. Beside, backup your data before begin uninstallation process as ALL data will be erased.
UPDATE: It's impossible to reinstall U3 LaunchPad........."
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is really appreciated for the FREE answering of your question.
Feb 12, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My password protected scandisc cruzer usb stick is refusing to accept the correct password-any solution
Unfortunately, you can NOT access your user data and applications on the device without a password.
If you think you are entering the correct password, ensure that CAPS lock or NUM lock is not turned on. You should try to type your password in another application (like word or email) to ensure that it is being entered correctly. This can help you see if CAPS lock, NUM lock, or a sticky key is causing the password to actually be entered incorrectly.
Password attempts
There's a set number of attempts before U3 locks your device and you have to reformat it.
Reformatting will delete all files and applications on the flash drive.
Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password you will have to reformat the drive.
It is recommended to keep a backup of all the data on your U3 device on your PC for safe keeping.
Jan 16, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
SanDisk 8gb drive with u3 installed How can I
  1. Run the launchpad program.
  2. Double click on the icon to open up the main windows.
  3. Click on Settings and the U3 Launchpad Settings.
  4. Click on Uninstall tab on the side and then Uninstall U3 Launchpad. Before you do this, make sure all the programs on the flash have been closed and all the explorer windows are closed, too.
After uninstallation, the drive has only one partition. The pesky ready only partition with U3 program is gone.
Dec 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have inserted the Cruzer Micro 2GB flash disk, its detected as unknown device i've gone to device manager tried checked driver details it says no drivers i've tried reinstalling the U3 launchpad but it...
I would try a different computer first if that does not work it may be the drive is bad and would need replacement. For the most part memory has a good warranty so you may be able to have it swapped by contacting the manufacturer.
Nov 15, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I can not format it
How do I uninstall U3 from my flash drive Most U3 smart drives come with an uninstall utility that converts the U3 smart drive into a regular USB flash drive. This utility can be accessed from the U3 Launchpad. Open the U3 Launchpad and click on Settings, then select U3 Launchpad Settings and click on the Uninstall tab. Some devices have a link to the Uninstall utility under Help and Support.
If you can not find the uninstall utility on your U3 smart drive you can download it from the following locations:
Remove U3
U3 removal tool for MAC
Jan 11, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Since 2 weeks I put my Kingston 2GB flash memory in USB, Kaspersky Internet Security destroyed the software of my flash, before "KIS" it was working well without any problem but now when I put it, only see...
Hi kamalmazhar2,
If you have a U3 drive and it is the U3 software you lost then there is nothing you can do to write the U3 software back to the drive. If you would like to simply recover use of it as a storage device without the U3 software then try formatting the drive. If Windows doesn't format it successfully then search for HP Format on the Internet and try using that to format the drive.
Kingston Tech Support
May 04, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do i get u3 back
Download the U3 installer from www.u3.com. It should solve the problem. Good Luck.
Feb 25, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Cruzer program no longer on flash after viruses were removed
New ones avail:
  1. Microsoft and SanDisk team up on U3 replacement - Engadget Microsoft and SanDisk team up on U3 replacement .... is actually pretty good, but they charge you extra to be able to install any program not on their list. ...
    www.engadget.com/2007/05/11/microsoft-and-sandisk-team-up-on-u3-replacement/ - 99k - Cached - Similar pages
  2. GnU3zer U3 LaunchPad replacement (download torrent) - TPB Oct 28, 2006 ... GnU3zer U3 LaunchPad replacement ... The windows CD autorun function can execute ANY program specified in the autorun.inf file provided it ...
    thepiratebay.org/torrent/3547144/GnU3zer_U3_LaunchPad_replacement - 16k - Cached - Similar pages
  3. Microsoft, SanDisk to Replace U3 Drives Microsoft and SanDisk on Friday announced a technology-sharing agreement that will produce a replacement for SanDisk's U3 line of USB smart drives by the ...
    www.physorg.com/news98193946.html - 55k - Cached - Similar pages
  4. Microsoft and SanDisk still working on StartKey - the new U3 ... Mar 7, 2008 ... Microsoft and SanDisk still working on StartKey - the new U3 replacement ... Microsoft and SanDisk Expanding on and Replacing U3 Smart ...
    www.u3-info.com/sandisk/microsoft_and_sandisk_still_working_on_startkey_the_new_u3_replacement - 13k - Cached - Similar pages
Jan 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
