Question about Casio Exilim Card EX-S600 Digital Camera
Cannot charge camera
All the buttons don't work.I re-inserted batteries,checked contact points but the charger still shows a blinking light.I just bought the camera 8/06.Thanks.
  • Anonymous Apr 26, 2008
    The charger light is blinking red and the camera won't turn on.
  • 4 Answers
Okay, the same thing happened to me. I ordered a new battery and that was not the problem since the same blinking light was haunting me! So I bought a wall charger for the battery alone and then it worked again on the original docking station. Apparently it will not recognize a completely dead battery on the docking station. It makes no sense but it worked for me. So good luck to you!
Posted on Aug 25, 2007
  • 374 Answers
BAD BATTERY. if it is less than one year old they will replace the battery for you. Contact tech support and give them your contact information. They will require you send in your battery and give you the address to send it to. Then they may be able to send you a replacement free of charge.
Posted on Jul 08, 2007
Battery wont charge
As in the first part of the manual is explained, when you have inserted the battery correct and you then plug in the charger, the charger light should go on. When the light is out, the battery is charged. When the light blinks, your battery is fault.
When the light does not go on, when you plug it in a power outlet, the battery is not inserted correct, or the contacts are dirty.
If you want to clean the contacts, please only use a dry cloth. Never us a sharp tool. It would damage the contacts bend repair.
Even when you plug in the charger, with a fully loaded battery, the light should go on for only a few moments.
Make sure the power outlet works normally. and the power cable is not defect.
Dec 29, 2013 | Fuji FinePix F460 Digital Camera
I am putting fully charged battery but it is blinking red for charging the battery
I had this problem. If you have the original Nikon charger, insert the battery and press the calibration button. I dont know how, but it charged the battery fully.
Sep 25, 2012 | Canon PowerShot A470 Digital Camera
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
I have a Fujufilm Finepix S5700 digital camera. Does not power up
hold power button down and remove battery at the same time once battery is out put battery into charger, if the light shows red then it needs to be charged if it shows green allow it to stay in the charger for 3 minutes then remove the battery and install in the camera pust the power button on hold for 5 seconds, if the camera comes on your ready to go, if not then you may have damaged the battery pack and will have to replace te battery. If you have a cable that plugs into the camera try using the powrord with battery plugged in, if it does not work then your battery is bad and you will have to purchase from fuji to get the right battery pack.
Jun 13, 2010 | Fuji FinePix S5700 Digital Camera
Is the red light on the charger suppose to stay on or blinking for the battery to charge?
It is supposed to stay on. If it is blinking then your battery has gone completely dead. You can force the charger to charge the battery by applying a voltage (AA battery w/ wires worked for me) across the charging terminals while inserting the battery. You'll have to take the charger apart for this.
May 17, 2009 | Vtech Cameras
Olympus battery charger flashes red when battery is inserted.
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Ccd-trv37 trouble with recharging battery
I think, battery is not being charged in camera.
  1. Plug the charger in AC out let.
  2. hook up with camera, check camera wroks with charger,
  3. set camera power button in OFF / Standby position,
  4. attach battery to camera and check any Charge-Light lit?
  5. If yes, leave it on charge up to 4-5 hours for new battery.
Aug 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Casio Exilim Card EX-S600 Digital Camera Logo
50 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
