Question about Samsung HLR5667W 56" Rear Projection HDTV
Samsung HL-5667W turning itself off
TV turns on fine. It wants to turn off if I do a lot of channel changing. Then a red lit "stand by/temp" shows up on the power button.
Wondering if there is a recall or something for over heating of the tvs.
ctf1800
  • 4402 Answers
SOURCE: TV KEEPS TURNING OFF ITSELF
how long does it stay powered on and do any of the lights flash if so how many times?
Posted on Dec 18, 2007
savenabuck
SOURCE: Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Posted on Dec 27, 2007
SOURCE: Samsung HL-S5679W
Just got mine fixed, it was an undersized Capacitor that needs to be replaced, call Samsung get local repair to come out replace and it took less than an hour for repair to be complete, working perfect every time now, some had to have two caps replaced
Posted on Jan 08, 2008
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
Samsung UN55FH6003FXZA won't turn on even though the red LED on the front is lit showing power is available. It did have a long delay to turn on, now not at all.
Samsung TV won't turn on + blinking red light (explained fix ...
? 4:03
https://www.youtube.com/watch?v=wEWzYLaKdgU
Aug 29, 2014 - Uploaded by Mysimplefix
(CC) (HD) A step-by-step repair video, showing the replacement of swollen/shorted "electrolytic capacitors ...Missing: un55fh6003fxza
bout 1,270 results (0.53 seconds) Search ResultsSamsung LCD TV LN32A330 power won't turn on - Forums - CNETwww.cnet.com > Forums > SamsungCNETMy 1 1/2 year-old LCD TV model LN32A330 won't turn on by direct and remote today. The red stand-by light is lit, but never blinks and the TV won't power up. A..Samsung UN55FH6003FXZA BN94-06418R Main Board ...www.shopjimmy.com/samsung-un55fh6003fxza-bn94-0641...ShopJimmyThis Samsung UN55FH6003FXZA BN94-06418R Main Board IC901 EEPROM ONLY ... TV won't turn on after being off for 30+ minutes - TV shuts off by itself
Jan 05, 2016 | Samsung Televison & Video
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
SAMSUNG DLP HL-R4667
It sounds like a bad color wheel (see photo) which will give a fan like or high pitched sound.
Very common on these sets and can be a do it yourself repair.
You Tube has complete video instructions for replacement for most of these models.
The wheel turns at over 12,000 rpm (very small part) and the bearings in the motor fail causing a fan like or whine noise.
If it fails all the way and shatters (it can) set will not even make it on---set is monitoring the wheel and if not at right speed or stops almost instant shutdown will happen.
see the photo and let me know if questions--replaced a lot of them and your description is classic.
Mar 19, 2012 | Samsung DLP HL-P5663W 56" TV
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Why is my 42" dlp tv turns itself off after awhile?
the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
do it fast
okay
Jan 05, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Screen is black but sound works
possible lamp is burned out,look in your manual for info.
Jun 26, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLR5667W 56" Rear Projection HDTV Logo
190 people viewed this question
Henry  Thomas
Henry Thomas
