Question about Coleman Powermate Premium Plus 6250W Portable Generator
How many gal tank is the Powermate 6250 10 KW
  • 169 Answers
Nearly all of the Powermates have the same 5 gallon fuel tank.
I'm a little confused, the Powermate 6250s are all 5Kw generators with 6250 watt surge ratings. Is yours really a 10Kw or did I misunderstand which generator you have?
Carl
Posted on Dec 12, 2008
I have a coleman powermate maxa 5000 generator model pm0525312 that needs a rotor assembly replacement. The rotor is not passing a continuity test. The rotor is 5.0 kw rf5 model 0049621.
This shows the rotor as obsolete and I'm guessing the stator would be too. Stators are in the $200-300 price range. Probably better to just buy an new generator. Jack's Small Engine shows some stators but not your P#.
Powermate PM0525312 Generator Parts
https://www.jackssmallengines.com/Products/POWERMATE/Rotors-and-Stators
Sep 30, 2017 | Electrical Supplies
2-4500 Watt heating elements, 4771 kw a year, 82 gal. SR#D97721792 have to hit reset button everytime tank empties
Empty tank remove and clean scale from elements. Re install elements with new gaskets, if needed.
May 19, 2015 | Water Heaters
Coleman Powermate 5000W has HIGH RPMs until a 3KW load
This generator is less than ideal to use as a home unit. see www.advanced-power-technologies.com and look at residential videos. Basically the voltage is governed by a capacitor on your unit, and ouput is directly propertional to speed. Also the engine is mechanically governered versus an electronic system. This is a common mistake using portables to power home equipment. You will damage your home digital equipment, do not use recommended
Jan 25, 2013 | Coleman Powermate Powermate 5000W...
Where do you buy the gas shut off valve for the 5000 power mate coleman generator with a 5 gal plastic tank.
Take the old valve, called a petcock, to a local lawn mower repair shop and they should be able to help you.
Jul 13, 2011 | Coleman Powermate Powermate 5000W...
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Fuel leaks from around the valve at the 5 gal plastic fuel tank
you twist the whole valve after disconnecting the hose...
get a new one and put it instead...
if u have any further questions let me know:
sal_kh_sab@yahoo.com
Jun 29, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Model Number BV6548049, pressure switch leak.
Usually, a leak at the pressure switch unloader valve is caused by the checkvalve in the tank. The unloader valve at the pressure switch bleeds out the air from discharge tube after compressor reaches set pressure. This only takes a few seconds. If air continues to leak then air is leaking back into the discharge tube past the tank checkvalve. Follow the air discharge line from the compressor to the brass valve at the tank. The brass valve is the checkvalve that holds the pressure in the tank. There are usually two connections at this valve. One is the unloader tube to the pressure switch. Simple test for leaking checkvalve, with pressure in tank unplug or switch off the compressor and remove the small unloader line at the checkvalve(brass valve) and look/listen for leak. If leaking, remove the checkvalve and examine seat/check for debris keeping the valve slightly open. If it cannot be cleaned, order generic replacement from www.grainger.com. It will cost less than the factory checkvalve. Just pay attention to the thread sizes for easy fit. Good Luck on your repair and email if you have questions.
Mar 25, 2009 | Coleman Powermate 60 Gallon Air Compressor
Gas used
11 Hours with a 50% load.
Dec 15, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
203 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
