Question about Kenwood VR-6050 Receiver
Loud cracking or popping noise through speakers with kenwood receiver
Frequently my receiver makes loud cracking or popping noises through the speakers (all 5 at differing times) when connected to a dolby digital device - both cable box and blue ray player in both coax and fiber optic cables have been tested. All the speakers are connected properly and all the power cords are also connected properly. This does not happen when I'm listening to a non dolby digital or dts signal. Any help? I can't seem to find a solution or reason that this is happening.
2 Suggested Answers
SOURCE:
mlapres
  • 757 Answers
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Posted on Jan 14, 2010
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
10 years and first problem to repair. When you turn on and select DVD or any other selection a very loud cracking noise comes through right speaker only. So loud (with volume tuned off too) that I fear...
I think your receiver is damaged.
Try this.
Mark the speaker wires on the back of the receiver. label the speaker connected to the left channel "Left" and the speaker connected the the right channel "Right"
Also pay attention to the polarity (positive an negative) making some type of marking on your speaker wire so you can reconnect them correctly.
Disconnect both left and right speakers.
Connect the speaker wire that is labeled "Right" to the receiver's left speaker connections only then turn your receiver on.
IF the loud noise comes back, this speaker is damaged. I am guessing that the speaker is fine.
Now connect the speaker that was labeled "Left" to the receiver's right speaker connections and turn the receiver on.
IF the loud noise comes back like it did before but now playing through the "good" speaker there is a problem with your receiver.
If so, your receiver is 10 years old. Isn't it time for an upgrade? Try ebay for good used equipment deals.
May 01, 2014 | Onkyo TX-DS787 Receiver
Cracking noise of Lexicon MC12HD
replace your hdmi cable between tv and preamp...lemme know if it works.
Feb 17, 2014 | Lexicon Audio Players & Recorders
I have an 05 Mazda 6, when my car is while idling it makes a loud cracking/popping noise.
A cracking or popping noise is frequently an indication of an air/fuel mixture that is too lean (too much air). Have a mechanic or mechanically inclined friend check the various vacuum lines on your engine. Sounds like a cracked or broken vacuum hose on the intake side of the engine. Good luck.
Oct 10, 2013 | Mazda Cars & Trucks
Woofer maiking a loud noise
be more specific, what type of noise? Humming noise or cracking noise or pop noise? can you still hear noise without signal input line connected?
Mar 05, 2012 | Acoustic Research 308 HO Speaker
Only makes a loud popping noise now
if it is still in warranty take to get fixed if not pull the case off and check the fuses if ones blown go buy a new one the correct size is written on them, if no fuses are blown then its worse, if you have friends who know about electronics  get them to look at it otherwise take it to a repair shop
Mar 21, 2009 | Kenwood VR-405 Receiver
JBL PB10 subwoofer, it makes a loud burp noise when it comes on.
In the industry - It is called "Turn-On Thump".
There are some manufacturers that eliminate components like noise filters on enry level lines to save money.
There is no way to lessen this noise without ripping the amplifier apart and having a technical knowledge of the way amplifiers work. It would involve hard-wiring a slow charge capacitor in the turn on line so it gradually builds power instead of getting it all at once.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 10, 2009 | JBL PB10 Subwoofer
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Kenwood Head Unit Making a Loud Popping Noise at the Start and Finish of each track
my mate had the same problem with his stereo in his case it was power related if u are usin crimp connections or any other form of connection to the speakers or the subs that is not a soldered joint it could be that we had to re wire his system with soldered joints and it worked ok. but other than that it could also be ur wires themselves with power cutting out cos the poppin sounds to me like the power cuttin out or in. other than that i really cant think of anything hopefully that helps
Jun 11, 2007 | Kenwood KDC-MP228 CD Player
Kenwood VR-6050 Receiver Logo
271 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
