Question about DCS WO-230 Electric Double Oven
Built-in Double Oven - Display fading
Digital display on front panel - lights are dim to unreadable. We have no idea how to proceed, but need to do so that we can read the temperature of the oven. Thanks, Jami
  • 3 more comments
  • Anonymous Apr 07, 2008
    This is the second time this has happened to ours. The first was replaced under warranty and the second is one is now out and 3 years old. To bad these nice ovens have a re-occuring (expensive) problem to fix.
  • anne2912 Jul 25, 2008
    Have the same problem with our double over by DCS -- Purchased in 2004 -- The display is getting lighter and hard to read
  • Anonymous Aug 31, 2008
    The Digital display on the front panel - lights are now dim to unreadable. We have no idea how to proceed, but need to do so that we can read the temperature of the oven.
  • betha99 Mar 25, 2009
    Having the same issue. Purchased oven in 2002 - must be the 7 year itch??
  • avirtuoso Apr 28, 2009
    I am having the same problem with my DCS oven display. The oven is a little over three years old, and the display has just became unreadable. I find it hard to believe that a quality appliance would hevae this issue. I have a cheap mircowave and toaster oven whose display are still going strong.
    Has anyone contacted DCS to see if they will back up their product?
I have the same problem with mine. Do you know what the approximate cost for the repair is?
Posted on Jun 24, 2008
Mine had the same problem. Got a replacement display unit from the local appliance store's parts dept for around $125. Installed it myself, problem solved... for now.
Posted on Jul 18, 2008
Http://en.wikipedia.org/wiki/Vacuum_fluorescent_display
Fade
Fading is sometimes a problem with VFD displays. Light output drops over time due to falling emission and reduction of phosphor efficiency. How quickly and how far this falls depends on the construction and operation of the VFD. In some equipment, loss of VFD output can render the equipment inoperable. Emission may usually be restored by raising filament power. Thirty-three percent voltage boost can rectify moderate fade, and 66% boost severe fade. This can make the filaments visible in use, though the usual green-blue VFD filter helps reduce any such red or orange light from the filament.
http://sci.tech-archive.net/Archive/sci.electronics.repair/2007-02/msg01395.html
You first need to identify whether it is the display itself which is at
fault, or the circuitry which drives it. Dim displays fall, I would say,
roughly 50 / 50 into low drive volts, and worn out. Often, the drive volts are derived from a voltage multiplier, and it is very common for the input capacitor to dry out and go low value, which leads to a low supply. This is typically about -30v DC when correct. The filament supply, which you can normally measure at about 1.5 to 3v AC, is usually floated on top of the -30v, so that is a good place to measure it. Most VFDs have a pair of pins at either end of the main row. Measure across these to check the AC filament supply, and from either one or the other to ground, to measure the negative supply. If these are all in order, then the display is worn out. Often, when it is worn out, there will be patches that are brighter than the rest. You may be able to squeeze a bit more life out of it by boosting the filament supply a tad, but if you go too far, the filament wires start to glow a little, and may become visible.
Posted on Dec 25, 2008
    Novelist:
  • 116 Answers
The VFD (Vacuum fluorescent display) will need to be changed, this means that the control clock will have to be changed unless you can find a local company to re-build it.
Posted on Mar 11, 2007
Gaggenau oven display clock unreadable.
The display may have to be replaced
Sep 01, 2016 | Gaggenau Ovens
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Front panel light is fading
Had the same problem. Replaced the display board.
Apr 12, 2010 | Thermador SC302T Electric Double Oven
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Temp/clock display faded
its the display that is going out on the ovenlike everything else things just fad away. Actually I have had LED meter displays do the same thing.
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
Jenn Air JJW8530C stopped working
can you hear audible tones form the machine when trying to set?? and just hte display has dimmed( amore normal complaint). all functions are working just the clock/display has dimmed to non readable state. if thats the issue youll need to replace the display part number 71003424 retails for about $165
Nov 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
DCS WO-230 Electric Double Oven Logo
887 people viewed this question
Top DCS Ovens Experts
Carmen Mikulic
NOEL
NOEL
Sal De
Are you a DCS Oven Expert? Answer questions, earn points and help others
