Can I buy the clips only instead of the entire box that holds the air filter?
SOURCE: any tools needed to change the engine air filter
Yes, for my 2008 3.5L Highlander, tools were required. First, make sure you get the right replacement engine air filter: there is a different part for the 3.3L and 3.5L engine. Next, as you pointed out, clips aren't used. There are two 10mm nuts that you need to loosen. They are captive (they won't fall out when you loosen them all the way). The one more in the front of the engine compartment is straightforward (once you get a 10mm socket wrench), but the one in the back is in a rather tight spot. I would suggest getting a long (6-8" shaft) 10mm nut driver. I managed to do it with a 10mm socket with a 1/4" drive and some determination. Also note that there is a wiring harness clipped to the top of a sensor adjacent to the air filter compartment; unclip it after you loosen the nuts. It works a little like a phone jack (RJ11) clip or a ethernet (RJ45) clip. Once the nuts are loose and the clip is off you lift up on the large black plastic housing marked 'see owners manual for air cleaner change' or something to that effect. (By the way my owners manual covered NONE of this.) The housing will tilt up and backwards towards the middle of the engine compartment. It won't come all the way off since it is attached to a few other things. Pull out the old filter. While it is out, you may want to wipe out the bottom of the filter compartment if you see any debris.
Note carefully that one corner is a "key"; it makes sure you install the replacement in the right orientation. Look at all four corners of the replacement part; one should look a little different. Toyota helpfully marks the replacement part with UP and FRONT. My Wix replacement had no mark whatsoever. Put the "key" corner on the corner that is more towards the front of the filter compartment and on the right side. Now put the filter cover back on. Note that one of the "hinges" goes into a socket that pops off when you remove the cover. Line that up first, then line up the rest of the cover, especially where the two captive nuts are going to go. While pushing down on the filter cover, tighten the captive nuts.
SOURCE: 2007 Toyota Avalon air filter replacement
Don't think there is another clip, I think it slips into a slot on the right. It should pop off.
