Question about Panasonic SC-AK75 Shelf System
Lights contine after i have turned it off.
They are nice pretty moving lights, but they continue after i shut the machine off.
It could be that the machine has turned off but it is in Demo mode for when on diplay in a store. It sit there running through all it's display options and possible combinations of features.
If you can set the clock on this, do so and it will shut down as usual and just display the time. If not this then not sure what else.
Posted on Mar 02, 2009
Ddw1802 wont turn off and continously drains
I would suspect the control board is defective.
Oct 31, 2016 | Washing Machines
Maytag washer (LAT7400AAV)shuts off during rinse cycle
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
Dec 10, 2014 | Maytag Washing Machines
Fault light and hazard lights and horn on continuously
hi, Has it got wet ?
If so water collects at the bottom of the switches making a connection, to fix carefully remove the base of the switch and dry, beware here will be a lttle string in there plus bits of plastic... so beware...
Regards
www.gewizrepairs.co.uk
Nov 19, 2013 | Electric Strider Midi 4 Wheel Mobility...
I have a admiral washing machine aav7000aww clothes deep coming out wet and had to be spun again. How making noise could this problem be caused by a bad bearing on the pump? The machine seems to be froze...
Yes, the pump should turn pretty easily. Mechanical pumps are generally pretty tuff though. Does it feel ballsy at all when you turn it? It should feel smooth, but it shouldn't spin fast like a top either. Of coarse, if it's quiet in your hand it should be quiet on the machine.
Make sure you check the hoses that you removed from the pump. There could be a sock or bra underwire stuck in the one coming from the tub. You might even try shining a flashlight up the hose and see if you can see it from the inside of the inner basket. A sock can be between the inner and outer tub but covering the drain hole. They make a racket and cause other chaos. With the pump off it's the perfect time to get it out before it moves to an unreachable spot, that requires dismantling. Check the basket closely with a nice bright light, if it's really jambed in there you may see it poking thru the basket holes. Let me know what you find.
Jan 13, 2013 | GE WSXH208A Front Load Washer
OMT Jukebox plays tracks continuously but will play selected track when ordered. Have turned off continous play button but it continues to play. Have programmed it not to play but it continues to play.
Perhaps someone has programmed the machine for "Play stimulator" (random play) or background music. The easiest way clear all f is to default the machine to factory settings. First, unplug the memory plug (red wire at bottom right side of selection and computer and turn off power to the machine for 10 minutes with the memory plug unplugged. After turning on power, the carousel will rotate to determine its capacity. After that the machine is ready for operation. Re-connect the memory plug. If you need further help you can contact me, tech@wurlitzer-ohio.com
Jan 20, 2011 | Wurlitzer Jukebox 1015 One More Time...
When I turn my wheel chair on sometimes it won't run at all and the light flashes red, green and orange and it won't move. other times it can me moving pretty normal and then all of the sudden it will...
hello visit: www.alldatasheet.com and download- troubleshooting_2007 SHOPRIDER.pdf AS A PDF FILE SAVE IT TO YOUR ADOBE READER,ANY PROBLEMS ASK AGAIN PLEASE ,HAVE A NICE DAY COLIN.
Dec 01, 2010 | Invacare Nutron R51 Folding Power...
I have a ventless gas heater. the pilot lights
It just has a little dust in the pilot safety and that makes it think low oxygen levels are present. Ti correct that situation I flush the pilot safety device with rust buster, I relight the heater with pretty good success. I have a page which shows where to clean and has a nice demo which shows exactly how it works HERE
Feb 28, 2010 | Heating & Cooling
Hobart lx40 Dishwasher stopped working
Look behind the dishwasher and you will see a cover on the right side,remove it.You may see a transformer with a fuse,check the fuse with a meter if you know how.Open the door look up to the right and left,you should see 2 phillip head screws,remove.Pull the top drawer with the display towards you.If you get this far let me know.
Apr 07, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Emachine w3615 keeps running
bug do a clean up run ccleaner and windows live one care free ok shut down the computer when u dont use it blow dust out inside well and get nice fans moving more the better
Jan 24, 2008 | Computers & Internet
120 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
