Just want to know how to put the belt back on
You need to remove the drum in order to replace the belt so that you can inspect and grease the rear bearing. Once the belt is around the drum and you know the glides and rear bearing is in order you make sure the belt is not twisted. You move the idler to the right and run the belt over the top of it and under the motor pulley.
How to get into the machine:
Note: westinghouse frigidaire gibson and kelvanator dryers are all basically the same.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
