Question about Motorola Mobility HS850 Consumer Headset
Indicator light turns off when boom is opened
Been using my HS850 and my RAZR for months with no problem, but now all of a sudden my headset won't connect anymore. The bluetooth signal flashes on my phone intermittently, but nothing comes through the headset. Tried to pair them again by pressing and holding the call button for a few seconds, and the light does actually become steadily lit, but as soon as I open the boom, it turns off instead of remaining on. End result is, neither device recognizes the other, even though the bluetooth signal flashes on my phone when I first power the phone on. I have tried several different variations of powering down the phone, waiting a minute, and then turning it back on. I've even removed the device from the phone, powered off, waited, then powered back on and tried to re-pair the devices. I'm thinking the problem must have something to do with the fact that the staedy light in the pairing mode shuts off as soon as I open the boom...it's supposed to remain lit in order for the pairing to work. Any ideas?
  • Lucy Higgins Mar 11, 2007
    My problem resolved itself when I turned off my headset, powered down my phone, and put them both on charge overnight. By morning, I was able to get the indicator light to remain on after opening the boom when attempting to pair them, so I was able to complete the process with no further problems. I'm thinking the solution must have come from actually turning the phone off when charging it overnight (some nights I just charge it up without turning the phone off if I'm expecting a call).
    So here's a new problem to post - how do you post a solution to your own problem on this website? You can only post when you are logged in, and when it sees my ID, it only gives me the option to post a comment...
    Genius:
  • 1,003 Answers
GO to www.n1 wireless to get another one cheap
Posted on Jan 15, 2008
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
I have tried everything . My Motorola Hs850 will not connect. It keeps indicating that the connection failed
Firstly, make sure you have enabled Bluetooth on your phone or whatever device your using the headset with. The default setting off, so go into your phones set menu and enabled Bluetooth.
You'll then need to 'pair' the headset and phone.
1. Ensure the headset is turned off (indicator light not blinking).
2. Press and hold the Call E button for 4 or 5 seconds. The indicator light will initially flash, but continue to hold down the button until the indicator light is steadily lit.
If the indicator light is flashing or not steadily lit when releasing the button, repeat both steps 1 and 2. Hold the Call E button for 4 or 5 seconds.
3. Enable Bluetooth on your phone and get to 'search for devices' it should find the headset.
4. Select Motorola HS850
Select OK or Yes to pair your headset with your phone. Enter the passkey: 0000 Select OK. When your headset successfully pairs with your phone, the indicator light changes from steadily lit to flashing.
Hope this helps. Oh and make sure your phone actually supports the headset!
Jun 13, 2011 | Motorola Mobility HS850 Consumer Headset
NEED TO PAIR BLUETOOTH HS850 TO RAZOR V3
a With the headset’s boom closed, press and hold the Multifunction Button E until the headset indicator turns on (about 3seconds). The headset indicator turns on.
b Release the button, then open the headset boom. The headset indicator remains on.
2. Perform a device discovery from the phone. 3.select motorola hs850 and click pair 4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone. The device ID is now stored in the phone’s memory. Pairing is successful when the headset indicator flashes 10 times rapidly.
Feb 07, 2010 | Motorola Mobility RAZR V3
I have a motorola hs850 and it keeps flashing blue and it cannot go into discoverable mode need some help thanks
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
May 17, 2009 | Motorola Mobility HS850 Consumer Headset
Bluetooth head set
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS850 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Sep 22, 2008 | Motorola Mobility Universal Wireless...
Motorola HS850 Headset gone silent
I bought a new HS850 and guess what, I got this hearing problem on the very first day ...phew ! I did the pairing with my Motorola A1200 phone and it worked for once, even the sound was coming in the earpiece and then I put it to charge for the first time and once done, I again started it up and it got connected with the phone and after that there was no sound in the ear piece. I was going nuts....about what could be the problem.
So i decided to delete the earlier paired profile from my phone and do the pairing again and guess what...It Worked....:) So you can try that out too....
Dec 06, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola HS850-
almost all of moto bluetooth headset get this problem. i think H680 is much better that HS850 or H700. i'm using RAZR2 V8 and almost all BT headset have static problem. So i end up with korean's and french's BT headset which have much lower static.
Dec 05, 2007 | Motorola Mobility HS850 Consumer Headset
Moto bluetooth HS850 WON't turn ON!
I think your guess is right a new battery may be required but try leaving it on charge for 12hrs or so sometimes if they havn't been used for a long time they go dormant and it takes a realy good charge to get them going
Nov 08, 2007 | Motorola Mobility HS850 Consumer Headset
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Aug 14, 2007 | Motorola Mobility HS850 Consumer Headset
Pairing Motorola RAZR with the HS850
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Aug 02, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
224 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
