Question about Dryers
I have a 2 year old kenmore series 400 electric dryer model 110.67422 and my problem is it will not get hot it turns light comes on just no heat i tested the contacts on the heating element with an ohoms meter and it read 0 any ideas
    Genius:
  • 1,122 Answers
If you got the meter to give you any reading the heater is good,so it must be the heaster box fuse,this fuse control the heat,if it get to hot it pops,.let meknow-mike
Posted on Dec 13, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My Kenmore series 90 Gas dryer doesn't heat up.
This dryer is what I like to call a 4 wheel drive model. Because it has wheels on the front as well as the back. To access the gas assembly you pop open the bottom panel. Strat the dryer and observe the gas assembly. You should hear a click and then the ignitor should glow. Next the flame sensor should trip and cause the ignitor to shut down. The gas will now be allowed to come out and fire off a blast.I have 2 home videos. on shows the operation and replacement of the coils. The other is of an electric model but shows how to put the dryer together.
Sep 21, 2012 | Kenmore 73052 Gas Dryer
Kenmore 400 series model # 110.77422600 will not heat when dryer is turned on only blows cold air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Oct 06, 2011 | Dryers
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
heatman101';
Jul 05, 2011 | Kenmore Dryers
We have a Kenmore 400 dryer. It gets warm but will not get hot--it is only one year old --what should we check for?
there are 2 thin coil wires that have current flowing threw it. it gets red hot and provides the heat to dry clothing, if one of these wires brake your dryer wont get so hot. very common its made cheaper all the time so it wont last.
Sep 24, 2010 | Kenmore 62622 Electric Dryer
My kenmore 400 series dryer will not start. It has electricity the inside light comes on when I open the door. I push the start button and nothing happens.
There is a thermocouple on the inside that prevents the dryer from getting too hot. If this burns out this opens the circuit so the dryer will not work but all other functions will work.
Sep 23, 2010 | Kenmore 400 6943 Dryer
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Kenmore 400 Series electric takes ver long time to dry.
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Mar 09, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Dryers Logo
131 people viewed this question
Top Dryers Experts
