Question about RCA D52W19 52" Rear Projection Television
Need to know how to install a flyback in 2004 52 in RCA tv.
Model no D52W19 52 in RCA tv how do I install a flyback
  • mikel1130 Feb 26, 2009
    Tv will not power on. the tv normally stays on most of the time it was shut off and would not come back on.
    when you try to turn it on there would be a slite flashing of the green power light with the remote. when you mashed the power button on the tv it would just blink no sounds. After messing with it a hour or so I left it for 3 hour and it did come on.
    I left it on for 2 weeks then we had a power outage and the same thing happened again. but this time i could not get it back on and after several hours trying the green light stopped blinking.
    could this be the flyback or what please help
  • 979 Answers
First and foremost, disconnect the power cord from the mains.
Next, after having removed the back cover from the set, discharge the tubes' residual high-voltage to ground using a suitable tool.
Access to the transformer is pretty much staightforward here.
A few hardware removals and you can then get to the board and transformer..
Mark, then remove all leads that go to the unit.
INstallation is the reverse of removal.
Be sure to replace the driver device, just to be certain...accordianman
Posted on Dec 12, 2008
I have an RCA 52 inch Model d52w19. It makes a sparking sound when turning on and I can see electricity flowing from what I think is a flyback soldier.
thats a common problem where the flyback will need to be replaced. The RCA repair kit called the 259296 flyback is the correct flyback for your model from www.tvrepairworld.com the flyback comes with installation instructions.
Sep 25, 2011 | RCA Televison & Video
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
Model d52w19 rca projection tv,will not turn on.the green power light blinks three times,but nothing happens.
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Mar 06, 2009 | RCA D52W19 52" Rear Projection Television
Need circuit board
You might be able to get some help from the owner of the RCA name;   Thompson Consumer Electronics
Mar 01, 2009 | RCA D52W19 52" Rear Projection Television
Tv turns on then turns off
you need to replace the flyback its the 259296 flyback which is available at the following link and they send free instalation instructions with detailed photos on how to do the replacement of the flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-flyback-259296/cName/flybacks
Feb 27, 2009 | RCA D52W19 52" Rear Projection Television
Tv not turning on
replace the flyback you need flyback # 259296 you can get the flyback at the following link with free installation instructions.
Removing the HV Wires from Flyback on RCA TV D52W19/
You really dont need it its only a wire.sliice and reconnect.
Feb 18, 2009 | RCA D52W19 52" Rear Projection Television
RCA = flyback?
I just posted a reply to you. Its most likely not the flyback causing that symptom.
Oct 05, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19 fix fuse name
thats not a fuse issue, its a defective flyback. You can get a replacement flyback at the following link with free installation instructions so you can easially install it yourself. You need flyback number 259296 here is the link.
Aug 22, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19
thtas the error code which means the flyback needs replacement. Its a inexspensive easy repair you can get a new replacement flyback at the following link for less than 50 dollars which includes shipping and free tech support to help you install it. You need Flyback 259296. Here's the link.
Jun 26, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
320 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
