Question about Akai MPC-4000 Plus Production Center (w/80 GB Hard Drive&Onboard Sounds)
Mpc4000 wont boot up, always read ''fatal error''.
Lcd screen stays dark
  • tafieindara May 11, 2010
    more details please about your problem
Toshibs sr3 bsod system wont boot up 0000007 fatal error is there a quick fix
You need to use the same as version/edition of your installed operating system (32/64 bit, Home/Pro/Enterprise) media to fix this problem.
Feb 26, 2014 | Toshiba SATELLITE PRO M70-SR3 LAPTOP LCD...
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
My dads toshiba A20-S207 has a dark monitor. Can very faintly see the windows xp logo at the beginning of boot up, so it looks like it is booting up, but the monitor stays dark. Can u help?
common LCD dark.dim screen problem, u can google keywords get more information.
either LCD inverter failure or CCFL backlight lamp failure, ask for a pro get it fixed.
by using a flashlight could you see the image on the LCD?
Dec 06, 2009 | Toshiba Satellite A20-S207 Notebook
Iomega Screen Play HD showing fatal error 05 -
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Sep 25, 2009 | Iomega ScreenPlay
When booting screen goes on for a second and blank after that
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 11, 2009 | Fujitsu Computers & Internet
Laptop wont boot up,
what did you make to the laptop? you dunk yor lapdop?plese anwer this question
Mar 30, 2009 | Acer Aspire 3690 Notebook
IQue 3600 Fatal Alert
You'll have to do a hard reset. Push the reset button, then hold the power button until the Palm Power appear and then release the power button. Next it will ask if you want to erase the data. I hate to said this but select yes. No will not work. Then after the inital set up run a HotSync.
Jun 18, 2008 | Garmin iQue 3600 GPS Receiver
Computers & Internet Logo
123 people viewed this question
Top Akai Computers & Internet Experts
Alun Cox
Michael Vincent Cruz
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
