Question about MSI 865GVM3-V Motherboard
Graphics i dunno if graphics card can be added into this motherboard.please let me know.and if its possible to do it, wat graphics card can i insert?thank you
  • 728 Answers
This board has a built in Integrated Intel Extereme Graphic 2 supports up to 64MB of video memory.  IF you are trying to upgrade it, you need a special kind of card.  It has a AGR (Advanced Graphics Riser) slot, which will only support compatible AGP VGA cards. What I suggest is to go to MSI's Hardware compatiblity  http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=∏_no=190   go to the bottom of the page to download the chart.
Good Luck!
Mark
Posted on Dec 12, 2008
After installing graphics card my pc restarts several times giving error message ur last boot failed or post interrupted press f1 to continue or del to enter setup im using ati radeon 5770 graphics card...
Hey there,Im pretty sure this is becuase one of 2 reasons:
Possiblity 1:That you have not inserted your video card correctly and some adjusting to its position on your motherboard should help(or even another pci slot if possible)
Possiblity 2:That the Card is not compatible With your system which is unlikley..
Regards,Finphillips
Please rate me
Jan 25, 2011 | ASUS P5N73-AM Motherboard
Hi, I'm thinking about adding a GForce 6200 LE graphics card to the system, do I need to disable the on board graphics ? And how do you do that ? Thank You.
A Geforce 6200LE would work perfectly with that motherboard, all you have to do is clip it into the AGP8x slot and disconnect your monitor VGA cable from the onboard graphics and into the 6200LE graphics card. Once the Graphics card is inserted correctly and plugged in your sytem automatically disables onboard graphics as it is no longer needed.
Please rate me high.
Thanks.
Oct 31, 2010 | PC Chips M957G Motherboard
I unplug my front audio connector cable and usb 2.0 connectors on my motherboard while putting in a new graphics card in the pci-e slot. After I inserted them back, my pc didn't want to switch on and I...
Uninstall the newly installed Graphics card and boot again. If it boots up normally, then the graphics card must be incompatible with your motherboard or might have some defect with it. Or if the system doesn't boot up even after the new graphics card is uninstalled, then you need to recheck the connectors and make sure everything is connected/inserted properly and fitted. The best way to check connection faulty is, plug-in one after another while you boot the system everytime... you plug in a connector. First connect the power switch and so on..
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 08, 2010 | Biostar MCP6P-M2+ Socket AM2+ GeForce 6150...
Expanding graphic card memory of D945GCPE
945 gcpe has not have AGP slot and PCI Express, it is not possible to upgrade Graphics, you can change your motherboard, if you want to update graphics.
Dec 26, 2009 | Intel Computers & Internet
ATI Mobility Radeon HD 2400
It is not possible to replace a graphics card on a laptop. The video chip is part of the motherboard and most likely the fix is a replacement motherboard.
How do you know it is a video card fault? If could just a back-light problem. Please follow my instructions to determine the fault and possible fix - click on this link :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 24, 2009 | Mobility Computers & Internet
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
I added a 256MB Graphics card but the monitor is not working. What should I do? Please help.
First time users get confused with this step. You should now connect your monitor to the graphics card, but not to the VGA that comes with your motherboard. After you insert the graphics card in the motherboard, use the screw to fasten it. Now in the graphics card, you'll have VGA, HDMI and another slot. So just connect one of them to your monitor.
Jun 03, 2009 | PC Chips P23G Motherboard
For adding an additional graphics card
Your board only supports AGP 4x graphic cards. You should be able to use any AGP 4x card or even some AGP 8x cards. Some of the 8x cards are backwards compatible but will run at the slower 4x speed. You can try places like TigerDirect.com or Newegg.com to see what they have available. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | Computers & Internet
Graphic card
you can use any AGP card up to 8X
Must be AGP NOT PCI-E and not faster then 8X
Jul 23, 2008 | Foxconn (865G7MC-ES) Motherboard
Lost internet connection - after installing graphic card
If this is the power problem then change your SMPS with more Wats power.
Jun 09, 2008 | VIA P4MA Motherboard
MSI 865GVM3-V Motherboard Logo
152 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
