Question about Ultrex 416-101 Deep Fryer
Deep fryer model # 14279
I am unsure of how to put it together again after I have cleaned it. Are the coils supposed to go in the pot with the oil poured on top of them??
Anyone know if covers exist for Dean Frymaster deep-fat fryers? I have three in a mobile unit and want to be able to move the trailer without draining the oil.
Hi there!
For open fryers, oil will still spill even with cover during transit because open fryer cover is not designed to contain/ hold oil inside the fry pot to prevent the spill, it is only designed to prevent foreign objects from falling inside the fry pot when not in use, draining the fry pot before moving the trailer from one location to another is only the best solution.
Regards.
May 08, 2012 | Frymaster Dean 2424G Deep Fryer
I need to know the best wayto clean the inside of an IFS40 deep f
Mr. Muscle Commercial oven cleaner, a good brush, a stainless steel scrubbie. Boil out the pot in accordance with Mr. Muscle directions. If all else fails, find "SWELL" oven cleaner in Restaurant supply, use rubber gloves. Spray on, let sit, Use brush and Scrubbie to remove. RINSE WELL!
Apr 27, 2010 | Imperial IFS40 Deep Fryer
Specific Oil to use?????
I would use either a vegetable oit or peanut oil. It really doesn't matter which kind as long as you keep the coils covered or the pot filled with oil.
Feb 01, 2009 | Rival CZF530 Deep Fryer
Just wandering how much oil to put in the 30 quart pot
thanks, all i did was put water in the the pot, took a three liter jug and emptied the water into it. it takes about nine liters , thanks again. jack
Dec 29, 2008 | Masterbuilt M30BV Deep Fryer
What is the "kettle"?
The kettle is mentioned as the fry pot just different slang.
Nov 06, 2008 | Pitco Frialator SG14 Deep Fryer
Welbilt DF 4050
That should be covered in the user manual, there is very little information available on this product, not even a user manual so its hard to confirm this.
Details:
Non-stick pot. Adjustable Thermostat. Interlocking folding handle. Permanent mesh filter. Convenient pour spout. Removable lid. Easy-view window.
at this time Im unable to give you a solid answer. Remove the lid and try gently. If you have the copy of the user manual, which I was unable to get my hands on, check it out.
Sorry for not having a solid answer.
Sep 03, 2008 | Welbilt DF4050 Deep Fryer
Fryer will not turn on
There's a red reset button that you need to press, it is hidden deep inside a well in the plastic piece. The well looks just like a screw hole until you know what to look for. Once you press it and your power supply is attched right you are golden.
Apr 19, 2008 | Euro-Pro F1061 Deep Fryer
Cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Oct 15, 2007 | Rival CF153-WM Deep Fryer
Immersion Element (
This should be the info you need; http://www.euro-pro.com/europro/faqdetail.aspx?modelno=f1063 on the left is the link for the user manual. Hope this helps - please ask again if you are unsure :)
Apr 12, 2007 | Euro-Pro F1063 Deep Fryer
Ultrex 416-101 Deep Fryer Logo
47 people viewed this question
Top Ultrex Kitchen Appliances - Others Experts
Ruth summersides
Tom Chichester
Are you an Ultrex Kitchen Appliances - Other Expert? Answer questions, earn points and help others
