Question about Acer AL1716B 17" LCD Monitor
Monitor problem hello, I just took this printer out of the box. Plugged it in and it comes up input not supported. Please tell me what that means. Thanks, Melanie
  • 624 Answers
Melanie, The computers video cards resolution and / or refresh rate is set incorrectly for your monitor. The easiest way to fix this is as follows for Windows 2000 or XP: -While the computer is first starting press the F8 key every second till the Advanced Options Menu appears. -Using the up or down arrow key select the ?Enable VGA Mode? and hit the enter key. -You will be taken to another screen that may or may not have several items to select from. Find your operating system, highlight it and hit the enter key. -Your computer should now load Windows using a generic display mode. Don?t be alarmed if the objects on the screen appear large, this is just temporary. -Log into Windows (if necessary) and you should now see your desktop. -Ignore the popup in the lower right hand part of your screen saying that the display is set very low. Simply right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) make sure it is set to 1280 x 1024. This is the typical resolution for a 17? LCD but be aware that your monitor will probably be capable of supporting other resolutions. -The color quality box should be set to the highest (most) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -The typical LCD is set to 60 Hertz; however, I have seen where some Acer monitors like 70 Hertz. I would start with 60 for now and change it to 70 if this doesn?t work. -click the OK button twice. -Restart your computer normally and see if it works. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Mar 09, 2007
My LCD syncmaster 2243swx screen display only 4 seconds and Black screen. When I touch Source the small box show digital / analog and 4 second display and black screen again.
It could be a power supply in the pc died and then it probably took out the video card. It could be spike in power source took out the PC or components.
The morel hear is prove it. What have you done to confirm it is the monitor have you connected a monitor that works to it like a old one that a friend has does not use it. As it stands not enough data to tell what the problem is.
You could be like a friend of mine He unplugged his PC from the box from the electric outlet to protect it from the thunderstorm and left the modem plugged in and the lighting came through and destroyed the whole system so he had to have a new box built which meant a new motherboard CPU memory hard drive DVD/CD drive power supply.
I just had the thought you could be talking about a TV and a cable company black box in which cause it could be you need to take the remote and change the input.
Jul 05, 2011 | Samsung SyncMaster 710VT TFT LCD Monitor
When i put pc on this message comes up on screen saying input not supported and it floats round in a little box.
This generally means you have the display resolution set higher then the monitor can support. To fix this press F8 after you turn the computer on. You may have to press it a couple times before the windows loading screen. A black menu will come up. Select safe mode. Your PC will load into safe mode with minimal drivers and settings. Go to the control panel and select display. Change your screen resolution to something lower then the setting is is at right now. If your screen is 19" or smaller try a setting of 1024x768 for starters. If its 20" or higher try 1280x1024 for starters.
Regards, Chris
Jun 30, 2011 | Acer Computers & Internet
Input Not Support
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Jul 18, 2010 | AOC 19LVWK LCD Monitor
Input not supported
could you please tell spcifics??
example what os are you running and what happen first before it showed input not supported, try to include your graphic configuration specially your graphics card model
Nov 10, 2009 | Office Equipment & Supplies
Cannot stop monitor adjustment box from comming up every minute or two ,very annoying,please help.
A few suggestions.
1. check all cords- plugged in to computer, plugged into monitor- no bent pins etc..
2. Virus scan
3. Restore computer to a time before this problem ocurred.
4. A warning - Selecting incorrect monitor settings may damage some monitors. For information on the settings your monitor supports, see your monitor documentation.
I suggest that you adjust your monitor settings. you can right click on your desk top, go to properties, select settings, and advanced. I suggest that you make small minor adjustments.
Mar 27, 2009 | Acer Aspire™ T180 PC Desktop
When energized, screen stays on for about two seconds then blanks
Hi...there,
Well, it's seems your monitor backlight inverter are bursted. Usually, the monitor had a 1 year for the screen panel and 3 years for parts and labors. You're still under warranty, send it back to manufacturer for repaired.
Nov 15, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1716B 17" LCD Monitor Logo
135 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
