Question about NEC Dterm DTP 16D-1 Corded Phone
DND on NEC Dterm 80 phone.
How do I set DND on NEC Dterm 80 phone?
SOURCE: taking off DND
press "feature" 69 then press "feature" again ~ problem solved!
Posted on Jun 17, 2008
SOURCE: NEC Dterm 80
I need instraction on how to put the phone on night mode
Posted on Aug 27, 2008
SOURCE: nec dterm series i dnd on
To turn off DND press feature, dial 69 press feature again. Hopefully this works, I tested it on my phone and it worked. I have an Electra Elite.
Posted on Nov 03, 2008
  • 149 Answers
SOURCE: How do you remove the DND feature on phone model NEC Dterm Series III?
Feature 69 feature.
Posted on Nov 13, 2008
SOURCE: How do you disable DND on NEC Dterm 80 phone WITHOUT DND button
Feature 69 feature
Posted on Apr 01, 2009
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Pls help to solve my problem NEC telephone IP2Ap-6TXD I set to DND external, how can i deactivate it please..
Feb 01, 2011 | NEC Dterm DTP-2DT-1 Phone
Dnd
TRY HITTING THE SPEAKER KEY DIAL 42 IF THAT DOESN'T WORK DIAL40.iT WILL ALSO DEPEND ON WHAT TYPE OF SYSTEM THE PHONE IS CONNECTED TOO.A KEY SYSTEM OR PBX
Apr 14, 2009 | Lands Phones
Nec dterm wont ring in
During an incoming call try holding the up arrow on the volume key. That is the only way I know to increase or decrease the volume of the ring. The phone might also be set on DND. in which case you have to Press feature dial the DND cancel code 69 press feature. If note look for you user guide here. http://www.neccare.com/cng/docs.nsf/Lib3?OpenView&Start=1&Count=100&Expand=6.13#6.13
Aug 21, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Dterm series i phone
with handset down press speaker and then #8
Aug 01, 2008 | NEC Dterm DTP-2DT-1 Phone
Taking off DND
May 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80
NEC Dterm 80 phone, 1 ext. is blinking and we can't get it to turn off. It shows a busy signal when you try to call it.
Help it is the owners phone!!!
Sep 29, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
159 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
