Question about Breville BKC600XL Coffee Maker
BKC600XL Stainless Steel Coffee Just purchased...during the priming no water entered the machime and it is stuck on "heating". I think i had the water filter on wrong. I fixed that but now need to reset to start the priming process over. How do I do that?
  • maxpower30 Dec 25, 2008
    I have the exact same problem. Machine never got through the 'priming' phase and was just stuck on heating. I unplugged the machine after an hour and now I can get it to say 'brewing' but no water comes out.
  • purchase575 Dec 25, 2008
    I have the same problem - hope this solution works
After trying just about everything (I had the exact problem you describe) I finally got it working.
In my case the reason why it was stuck on heating is because no water was getting into the heating tank. I removed the charcoal filter, unplugged my machine and plugged it back in again. I then saw the water resevoir level drop and knew that water was now being heated.
I made a couple of cups of coffee then put the charcoal filter back in and now everything is working great.
I hope this helps your problem.
D
Posted on Dec 25, 2008
What are the features of Breville BES870XL Barista Express Coffee maker for my home. Where can I buy it in good discounted rate?
FEATURES OF bes870xl_barista is as follows -
  • 15 Bar Italian Pump and 1600W Thermo coil heating system
  • Purge Function: Automatically adjusts water temperature after steam for optimal espresso extraction temperature
  • Stainless steel conical burr grinder with 1/2 lb. sealed bean hopper
  • 67 fl.oz (2L) removable water tank with handle
  • Newer model of the Breville BES860XL Barista Express
It has stainless steel color. And you can order it great discounted rate from where I purchased it after comparing all the other brands and prices also. Best Espresso Machine is one of the best site to compare and get best detailed knowledge of every brand....
Oct 07, 2016 | Breville Coffee Makers & Espresso Machines
Coffee grinded but no coffee coming through
Got water in unit? is it heating water? is there a blocked pipe so no water come through? for last 2 remove coffee handle push button to pour coffee and see if water comes out and if it is steaming hot.watch ,don't touch hot water .
Sep 06, 2014 | DeLonghi Esclusivo Gran Dama EASM6600...
Coffee maker will not prime.
E05 means "Water circuit blocked. No water in flow meter or flow meter not turning (jammed)".
Since I got it when I had not descaled for a month, I poured in tripple strength descale in the water container, and restarted the machine 3 times. Noticed that it took in a small gulp of the descale. Waited hours. Restarted 3 times again. Waited... and after about 20 restarts over 2 days. When I almost had given up it primed and was able to do a normal descaling.
I forgot to weigh how many grams of descaled it took in after each restart. That would have been nice for troubleshooting.
Apr 06, 2014 | Saeco Exprelia Automatic Espresso Machine...
Describe your BKC600XL Stainless Steel Coffee Maker Problem water comes out ,not in cup though.
Hello, bt
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Aug 27, 2011 | Breville BKC600XL Coffee Maker
I just purchased a Bialetti stainless steel 6-cup stove top espresso maker. I cleaned it, assembled it according to the instructions, and went to brew my first coffee. I didn't grind the coffee too fine,...
There is a valve in the compartment where you place your fresh, cold water. This valve must not be covered as it is necessary in building up steam pressure to push the brewed espresso upwards. Also, most stove espresso makers have a rubber type gasket that is usually placed on the base of the upper part of the maker. Check that you have a gasket.
Apr 19, 2011 | Bialetti 4cup Stainless Steel Espresso...
Water not coming out. How do I clean the machine?
The Instruction Booklet for the Breville Gourmet Single Cup Brewer for the BKC600XL / BKC700XL can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/Breville_BKC700XL.ashx
The booklet has an extensive section on cleaning.
Mar 12, 2011 | Breville BKC700XL Stainless Steel
I used the filter with my own coffee and now it is clogged. How do I fix it?
The Instruction Booklet for the Breville Gourmet Single Cup Brewer BKC600XL / BKC700XL can be found here:
See Page 32 for Troubleshooting. You may need to unclog the Exit Needle and run a cleansing brew.
Mar 06, 2011 | Breville BKC700XL Stainless Steel
My Breville Keurig coffee maker turns itself off after heating water...why?
mcdevito75 here, It may need to be cleaned, if the brewing holes are clogged it"ll signal coffeee maker to shut off. Refer to owner manual for cleaning.
Jun 22, 2010 | Breville BKC600XL Coffee Maker
Breville BKC600XL Coffee Maker Logo
641 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
