Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Tappan Microwave oven
Whenever I open the microwave door the turn table continues to turn and the fan stays on. How do I correct this problem? Tappan: Model# 56-9439-10/01 S/n# HG94314349 700 Watts Year Nov. 1989
    Novelist:
  • 116 Answers
One of the door interlock switches are stuck. this is the latch mechanism the the door locks into. This is usually accessed behind the control panel, you may have to remove the outer skin of the microwave first. Be sure to unplug the machine for at least 1/2 hour before doing so and do not touch any exposed wiring connectors and stay well clear of the magnetron and capacitor. Do not operate the microwave with the cover off. At this point you can see the latch mechanism as you open and close the door. There will be several small switches on the interlock assembly and they will all need to be tested electrically (multimeter) to isolate the problem switch
Posted on Mar 11, 2007
SOURCE:
Microwave starts when door opens
Time to buy new one. It's cheap
Good luck
mai
Aug 10, 2015 | Magic Chef Microwave Ovens
Troubleshooting- microwave turntable and fan run constantly when door closed, door switches test good, timer can be set and oven runs otherwise; need amana microwave ACM1580AS wiring diagram
I'd look for a defective relay or shorted triac on the control panel circuit board. Either could cause this problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 24, 2015 | Amana Microwave Ovens
Why does the fan and turn table run when door is opened - ge microwave
I'd be AWFULLY NERVOUS about that - you don't know if the magnetron is also generating microwaves. If it IS, it can give you cataracts and/or blind you.
Aug 12, 2014 | GE Countertop Microwave Oven
My Tappan TMV 151FS (2008) microwave is not working.
You likely have a door switch or mount. See a handy help file on door switches here.
The service manual for the TMV151 model series is here, and the parts manual is here.
You can order Tappan parts from the Pros here.
Nov 30, 2012 | Tappan TMT104E1 Microwave Oven
After closing door micro wave turn table continues to turn and light stays on after you open door and take out food.
The problem is most likely caused by a defective door switch, and should be rectified for safety reasons.
Apr 05, 2011 | Whirlpool WMH1162XVS Microwave Oven
I have a Tappan Model 56-9338-10/04 Microwave. The microwave stays on when you open the door! Can someone help?
  • Don't operate an oven if the door does not close firmly or is bent, warped, or otherwise damaged.
  • Never operate an oven if you have reason to believe it will continue to operate with the door open.
  • As an added safety precaution, don't stand directly against an oven (and don't allow children to do this) for long periods of time while it is operating.
Nov 28, 2009 | Microwave Ovens
Advantium 120 Keeps running
I've got this problem also.
The interior light on the oven died. We replaced it. Since replacing it the light stays on and the turn table turns.
Looking at the diagram, the "main relay" is what powers both. My guess is that it's stuck in the "on" position. Solution will be replace the relay.
Long term fix may be bigger relay.
Jan 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
128 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
