Question about Averatec 6200 Notebook
Averatec 6200 new hard drive trying to reinstall factory cds
There are (3) cd included in restoring factory installed system. I,am able to install cd#1 but cd#2 I get 63% with it stoping at fxsst.dll and show an erro screen for 3 sec can see all the words but it say to reboot. I do and the same thing happens. I just installed a new hard drive and still get the issue...Please help??
  • 6 more comments
  • kasselco Dec 12, 2008
    Thank u I,ll try it
    Whats the best way to clean off the contacts?
    O K Tryed that.....Now seeing if I can copy the cd to another machine and than i,ll make a new cd if the copy goes well. This should elimanate weather it,s the cd or the ram. I ordered new
    ram two days ago just to give me more memory. I,ll keep you posted..Again thanks for the tips.
    Kurt
  • kasselco Dec 13, 2008
    The new hard drive for this Averatec 6200, do I have to format it and how?
    If in the event the new roms and new hard drive doesnt fix the issue and I cant get a copy of the three factory cd,s can I install a new clean windows os?
    O.K. Here we are. new hard drive...new rom and still stops at cd#2 same place with an error msg 256. I can only guess that it is the #2 cd? The unit is out of warrenty so I thinking of buying a new OS windows xp home edition but not sure if I will have a problem with factory drivers. Thanks again for staying with me on this issue
    didnt know that. Well it looks as if it,s the cd. the latest error
    saidabort can not read file. I assume it,s the cd file that isnt being read?
    Thanks for all the help I,am glad I stoped by. I let you know the out come...Regards
  • Averatec Master
  • 4,806 Answers
Hi there
The problem is that the #2 recovery cd is probably corrupt and unreadable, before you come to this decision take out the memory modules, clean them & reseat them and try the install again, if you get the same error and your pc is still under warranty get in touch with the pc manufacturer and the should send you replacement recovery cd's at no cost to yourself
Kind regards and please don't forget to rate us
Posted on Dec 12, 2008
  • 3 more comments
  • Lee Hodgson
    Lee Hodgson Dec 12, 2008
    Hi again
    The best way to clean the contacts is with a pencil eraser, use a dry clean paint brush to also clear any dust away from the memory slots also (don't forget to brush any residue left behind by the eraser on the memory)
    regards
  • Lee Hodgson
    Lee Hodgson Dec 13, 2008
    Hi
    Your install cd's should do this for you
  • Lee Hodgson
    Hi again
    Yes you can install from a new install cd, although i don't think the problem is the hard drive, Averatec you replace your recovery cd's for you
  • Lee Hodgson
    Don't bother with XP home edition as it is not supported by microsoft anymore, i would suggest you purchase XP professional, its supported up to 2013
    kind regards
  • Lee Hodgson
    yes as i stated earlier the #2 restore cd is corrupt and unreadable
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
Installed the restore cds they dont have any instruction manual
Glad to HELP YOU!
To RESTORE your system as it was out from the factory (if I got it right...) and if you have the RESTORING CDs you have to do like this:
### insert the first CD (if are many) in the tray ###
1. RESTART your machine
2. when the LOGO SCREEN appears press F8 or F10 or F11 (it depends on each brand) and select the BOOTING MEDIA - in your case the CD MEDIA/DVD MEDIA
3. select FACTORY RESTORING or DEFAULT RESTORING or SYSTEM RESTORE
4. follow the instructions as they will appear on your screen
5. let the machine reinstall its system
You're done!
WARNING: WHEN YOU WILL REINSTALL THE SYSTEM YOU WILL LOOSE ALL YOUR FILES FROM THE HARD DRIVE!
So save on an external hard drive or on some DVDs your precious files.
My best wishes!
Mar 23, 2011 | Computers & Internet
How to repormat a laptop
Before reformatting the pc you must back up necessary files and applications that you might have. Because during the process all files would be deleted and pc would be back to its factory default. You may follow the steps below to reformat the pc.
1. Turn on the computer. When the Dell logo
appears, press <F8> several times to access
the Vista Advanced Boot Options Window.
2. Select Repair Your Computer.
3. The System Recovery Options window
appears.
4. Select a keyboard layout and click Next.
5. To access the recovery options, log on as a
local user. To access the command prompt,
type administrator in the User name
field, then click OK.
6. Click Dell Factory Image Restore. The Dell
Factory Image Restore welcome screen
appears.
NOTE: Depending upon your configuration,
you may need to select Dell Factory Tools,
then Dell Factory Image Restore.
7. Click Next. The Confirm Data Deletion
screen appears.
NOTICE: If you do not want to proceed with
Factory Image Restore, click Cancel.
8. Click the checkbox to confirm that you want
to continue reformatting the hard drive and
restoring the system software to the factory
condition, then click Next.
The restore process begins and may take
five or more minutes to complete. A message
appears when the operating system and
factory-installed applications have been
restored to factory condition.
9. Click Finish to reboot the system.
Operating System Reinstallation
Before you Begin
If you are considering reinstalling the Windows
operating system to correct a problem with a
newly installed driver, first try using Windows
Device Driver Rollback. If Device Driver Rollback
does not resolve the problem, then use System
Restore to return your operating system to the
operating state it was in before you installed
the new device driver. See "Using Microsoft
Windows System Restore" on page 38.
NOTICE: Before performing the installation,
back up all data files on your primary
hard drive. For conventional hard drive
configurations, the primary hard drive is the
first drive detected by the computer.
To reinstall Windows, you need the following
items:
• Dell Operating System media
• Dell Drivers and Utilities media
Restoring Your Operating System
NOTE: The Dell Drivers and Utilities media
contains drivers that were installed during
the assembly of the computer. Use the
Dell Drivers and Utilities media to load any
required drivers. Depending on the region
from which you ordered your computer, or
whether you requested the media, the Dell
Drivers and Utilities media and Operating
System media may not ship with your
computer.
Reinstalling Windows
The reinstallation process can take 1 to 2 hours
to complete. After you reinstall the operating
system, you must also reinstall the device
drivers, virus protection program, and other
software.
1. Save and close any open files and exit any
open programs.
2. Insert the Operating System disc.
3. Click Exit if the Install Windows message
appears.
4. Restart the computer.
5. When the DELL logo appears, press <F12>
immediately.
NOTE: If you wait too long and the
operating system logo appears, continue to
wait until you see the Microsoft® Windows®
desktop; then, shut down your computer
and try again.
NOTE: The next steps change the boot
sequence for one time only. On the next
start-up, the computer boots according to
the devices specified in the system setup
program.
6. When the boot device list appears, highlight
CD/DVD/CD-RW Drive and press <Enter>.
7. Press any key to Boot from CD-ROM.
Follow the instructions on the screen to
complete the installation.
manuals are here http://support.dell.com/support/edoc...5/en/index.htm
Mar 23, 2011 | Dell Inspiron 1525 Laptop
When turned on it show black screen and automaticaly shutdown
Hello.
Either you have a memory issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
It's also possible that your Master Boot Record is corrupted. To fix:
2. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
3. Once the setup loads, you will see the option to press R to repair a Windows installation.
4. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password.
5. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Also run the fixboot command to repair the boot sector with a new one.
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Jan 25, 2011 | Fujitsu LifeBook A3130 PC Notebook
I was just on my ibm t43 and it froze so i manually turned it off now it wont turn back on. it acts like it is going to then it pops up a screen that say an problem has been detected
Hello, Meagan.
Sounds like an operating system problem.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If you can't access System Restore by Safe Mode, try Offline System Restore:
1. Boot from the DVD
2. Select the Language
3. Click on "Repair your Computer" on the Install now screen
4. Click next on the System Recovery Options screen
5. Click on System Restore.
6. Choose the date to which you want to restore
Hope this helps.
Apr 19, 2010 | IBM ThinkPad R40 2722 Notebook
How do i restore to factory settings for my hp pavilion zt3000 without the cds
There's basically no such thing as "restore to factory settings" when it comes to PCs.
You can restore the BIOS setup to factory defaults, but it's rather improbable that something got messed up there.
To have the system like it was fresh out of the factory, you have to wipe your hard disk and install the operating system (Windows in this case) anew on the hard drive, and for that you need the system reinstallation CD. Then you need to reinstall all the computer-specific drivers and bundled applications that came with your computer. For that you really need at least your Windows CD, the drivers etc. can be downloaded from manufacturer's support websites.
And then all the system updates that appeared for your Windows version over time need to be installed as well.
Nov 26, 2009 | Toshiba Satellite M115-S1061 Notebook
Windows dont start
Averatec is famous for not supporting their laptops after they sell them. If your system is giving missing files after a full restore, it's possible you've got some bad hardware. Try running a memory test by downloading memtest86+, and burning it to a cd. It will need to run overnight. If you've got bad ram, replace it. You can also test your hard drive by downloading the support softare for your specific brand of hard drive. Maxtor used the maxblast, western digital used powermax, and hitachi/ibm uses another, but I can't remember the name. Try those, and let me know.
Steven
Sep 17, 2008 | Averatec 6200 Notebook
Want to restore my computer back to factory settings and wipe my hard drive clean i am having to many problems wiht my computer i have a averatec 77100 series
Not sure which Windows version you have, ie. 98, XP, Vista...
Have you tried reinstalling or repairing Windows from your Windows installation CD?
Make you have the product key issued with CD otherwise you will not be able to reinstall.
Other options are:
Have you created a previous backup using a 3rd party backup software?
Have you created a startup disk?
You should conider any steps that enable you to reverse what you do.
Sep 14, 2008 | Averatec Computers & Internet
Will not read any disc.
Dear Kentrell,
Please try to run cd lens cleaner once ,maybe the problem is rectified , if no then please contact to any authorised service centre to replace this optical drive.
Regards
Sep 10, 2008 | Averatec 6200 Notebook
Averatec 6200 Notebook Logo
254 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
