Question about Fujitsu Siemens AMILO Pro V7010 Notebook
Don't Swith 0n
The notebook don't Switch on. The battery is OK and also the AC supply is OK. The charge lamp is of but the 19 Volts are present inside the noteboock
    President:
  • 1,223 Answers
So ac supply is ok battery is ok then mother board is dead i worry pls check it out
Posted on Feb 20, 2009
Dash lights don't work 91 Toyota pickup
Check the dash lite fuse first, if that is ok remove the dash lite dimmer control switch and check to see that 12 volts is present at the switch with the headlights turned on, the dimmer is defective if you have 12 volts present.
Jun 06, 2013 | Cars & Trucks
Eee pc x101 won't charge
You need a new AC charger the wires wear out very often with constant plugging in and out im on my fourth one.Buy the full charger and cable.Ebay less than a tenneerr
Aug 17, 2012 | Asus Notebooks Asus Eee PC X101CH-EU17-BK...
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Sep 14, 2011 | Computers & Internet
Engine light and battery light comes on about every other time i start it and te battery is not charging all the time
To check the charging system, first make sure you have a fully charged battery in the bike. You'll need a DVOM (digital volt ohm meter). Set the meter's function selector switch to DC VOLTS, 50 volt range. Connect the red meter lead to the positive battery post and the black meter lead to the negative post. Start the engine and bring it to a high idle. After a minute or so, your meter should read between 14.5 and 15.0 volts. If not, proceed to check the output voltage of the alternator.
Follow the two black wires from the voltage regulator down to the connection on the front of the engine. Unplug the connection and look down inside the engine side of the connector. You'll see two metal contacts. Make sure they are clean. This is where you're going to put your meter leads to read the output of the alternator. Since it is an AC voltage, it makes no difference which meter lead goes to which contact as long as they don't touch each other or the engine case. Put your meter's function switch to AC VOLTS, 50 volts or greater range. Start the engine and bring it to a high idle. Touch a meter lead to each of the metal contacts. You should read at least 30 Volts AC. If not, your alternator stator is likely bad. If you do read the 30 volts or more at the alternator but not the 14.5 to 15.0 volts at the battery, your voltage regulator is likely the problem. Make sure your voltage regulator has a good ground against the frame.
Good Luck
Steve
Jun 01, 2011 | 2007 Harley Davidson FXSTB Softail Night...
Replace alternator or drive making noise not charging battery
If your alternator is not charging and is making a noise down in the primary, make sure you check the magnets in the rotor. They have been known to come loose making a noise and damaging the stator.
Good Luck
Steve
Jun 01, 2011 | Harley Davidson DNA 50 Motorcycles
I have a 2001 flhtcui what are the ac reading coming from stator at 2.5k rpm 3k rpm and 3600 rpm. At 2000 rpm I get about 12 volts dash guage reading but at 3000 I get 13.5 to 14 at lower rpm 2000 or so I...
The AC output of the stator should be 32-40 volts at 2000 RPM (16-20 per 1000 RPM). With the battery fully charged, your regulator should supply between 13.5 and 15.0 DC volts to the battery. This should be the reading you get on your voltmeter. It will vary depending on what lights and other equipment you have turned on. Sounds like everything is working fine to me. The gauge is reading the DC voltage at the battery while the engine is running. At 2000 RPM, 12 volts is a little low but, considering the accuracy of the gauge, as long as it doesn't fall below 12 volts, it's about right. You don't ride for extended periods at engine RPMs that low. Then at 3000 RPM, 14 volts is about right. If your bike never ran anymore than 12 volts, your battery would slowly go down. If it goes any higher than 15.0 volts, it will boil the battery. Usually, about 14.3 or so with no load on the system is about right.
Good Luck
Steve
May 17, 2011 | 2001 Harley Davidson FLHTCUI Electra Glide...
I have a HD 2001 ultra clasic not charging have replaced the regulator still no charge. when I turn the key switch the blinker lights flas 6 times can you help me Rick
Just to add to "wd4ity" very comprehensive test. If the battery voltage with the engine running is within the range quoted, Your problem is your battery. Over time the electrolyte or the plates degrade and they go to the great battery shop in the sky(just like all man made things.
May 02, 2011 | 2004 Harley Davidson FLHTCUI Electra Glide...
Battery will not show or charge even with new battery. It will run on a batery that has a charge in it but will not charge one. Is there a fix or is there a charger that can be use instead of one in...
With my laptop, I held the power button (still with everything removed) for 30 sec to decharge the capacitors. Finally, put the battery back in and plugged in the adaptor and everything worked
Jan 11, 2011 | Sony VAIO VGN-A790 Notebook
My battery dies very quickly
If your notebook unexpectedly goes into Sleep mode while you are using it but the battery charge is not low, you may need to recalibrate your battery. You should also recalibrate the battery periodically to maintain the accuracy of the battery gauge. Follow these steps to recalibrate the battery.
  1. Connect your notebook to AC power and let the battery charge completely.
  2. Disconnect the AC power and restart your notebook.
  3. Completely discharge the battery.
  4. After the battery is completely drained, reconnect your notebook to AC power.
  5. Charge the battery completely until the battery status indicator turns blue.
Oct 28, 2010 | Gateway T-1625 Notebook
My question is , i have 4 Argus LCM PLUS PATIENT MO NITER AND THE PROBLEM IS DOESN'T WORK IN ALTERNATIVE VOLTAGE,IT IS ONLY WORK BY BATTERY after a weak the battery is low in the display.. PLEAS ADVICE...
There are two supply systems are in your machines. One is for charging the battery, and other is for bypass AC power converted to Dc ; when AC power is present. That is when AC power is present, your machine will work on that power, and charge the battery simoultaneously. When AC power is inturupted, it will automaticaly change over to battery power. But the power consumtion of your machine is high. Therefore battery power will get downed soon. Battery is placed inside the machne only for urgent power faulure use. Not for continous use. Both the power supplies are SMPS [Switched Mode Power Supply] types. We can't prophet the reason for its failure. We are repairing such machens here. Now your machines battery charging circuit is ok. AC power bypass is faulty.
Email; gopakumarg43@ymail.com.
gopakumar1@hotmail.com
Trivandrum, Kerala.
Oct 13, 2010 | Schiller Welch Allyn Cardiovit At 2...
Computers & Internet Logo
254 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
