Question about Technics SC-EH780 CD Shelf System
How do i adjust balance on ch530 ??
Simple i'm sure!
But i am simpler!
Simon
Technics SC-CH530 Barely audible CD player
Have you tried cleaning the unit, there are discs to do that, 4 years is a long time?
Dec 26, 2017 | Technics Audio Players & Recorders
Tip
SERVICE MODE POWER SUPPLY AND INVERTEE CIRCUIT
White balance adjustment
Pre-adjustment
The set should be working for over 30 minutes before white balance adjustment so that it can be in a stable state. Use white balance apparatus CA210 and change to BBY channel to adjust white balance; Only need to adjust chromaticity coordinates when color temperature is 10000K (namely "COOL") for the unit. To meet testing requirements of BBY when color temperature is 8000K or 6500K, make sure chromaticity coordinates of bright scale is X=280 ± 5 Y=288 ± 5, chromaticity coordinates of dark scale is X=280± 8 Y=288± 8; Manual adjustment of both groups of white balance datum YPbPr white balance adjustment.
FOR MORE CHECK
Electronics Equipment Repair Center
on Feb 14, 2015 | Insignia Televison & Video
Serpentine belt keeps coming off. does harmonic balancer keep it on. how do you change it
Make sure you have the right size belt. If it's old then replace it. Then make sure you run it correctly or it can slip off. If it still slips off then check all your pulleys for chips or wobble before you replace any pulleys. I hope this will be some simple help for you.
Apr 28, 2016 | 2005 Chevrolet Monte Carlo
Both speakers on the left side has quit working
Try adjusting the balance or fade, it will be balance for left to right speakers to be adjusted, it may be as simple as this.
Apr 17, 2011 | 2004 Nissan Sentra
I have overloaded the washing machine and now it is off balance and i need to know how to fix it
Kenmore top loaders are equipped with an auto-leveling system on the back two feet of the washer. Typically, what happens when the washer becomes off-balance it's a simple matter of the auto-leveler needing to be readjusted. This is a very simple process that requires no special tools. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The rear auto-leveler should be periodically checked from time to time to ensure the washer maintains level. Any excessive vibration may cause the rear of the washer to become mal-adjusted. This is normal. Once the rear feet are properly leveled, make sure the front feet are adjusted so that the washer is level front-to-back and side-to-side. Use a level across the top of the washer cabinet (NOT the lid! The lid on most washers is slightly bowed.) to check.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Oct 06, 2010 | Kenmore 24032\24036 Top Load Washer
How can I disconnect the motion sensor from the GE Simon 3 Wireless Home Security System?
Your wireless motion detector has been "learned" or programmed into your system. It may be difficult to remove it without a knowledge of how to de-program and you'll also need an installation program manual. A much simpler alternative is to mask off the lens portion of the motion detector. If you are able to open the case cut a small piece of cardboard or heavy stock art paper and place it in between the motion's circuit board and the lens assembly. Once reassembled this will block the detector from seeing motion. If you can't figure out how to open the case another way is to take a piece of cardboard and tape it over the lens face on the outside. Hope this helps.
Apr 15, 2010 | GE Security Simon 3 Wireless Home Security...
I have the Simon 3 security system with one motion detector installed. I didn't set this system up but would like to add another motion detector and was wondering how hard this is to program it into the...
I don't of any system that is simpler to add a device to. The process is in the manual and is something like press "add" on the panel, follow some prompts and press a button on the rear of the motion sensor. Pretty easy if you dont have keypad phobia. Electronic version of the manual is at this location (adding a sensor starts on page 18).
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
Mar 19, 2010 | GE Security Simon 3 Wireless Home Security...
Very dark screen and poor white balance
The digital sensitive lens has worn out... that part needs replacement... If you know where to buy or a repair center can solve it, if they have that part....
Good luck.. happy Fixya
Feb 04, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Technics SC-EH780 CD Shelf System Logo
82 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
