Asus motherboard p5b-mx wifi won't display vga
I just bought an Asus P5B-MX WIFI motherboard with intel core 2 up to 64 bit and 1gb ram all installed.
The leds and internal speaker are all connected.
The power supply is an Atx 450w.
All is connected well and i use the onboard vga.
Dvd and Hard Disk are connected.
When i switch the power on ,every thing runs normaly, the Green Led is on for power ,the dvd open and close and the cd inside is spinning ,the HD is running (I can sense it),
the cpu fan is running but THE DISPLAY is not showing any activity and the whole thing doesn't boot on post .
What is the problem?
I tried to take off the Ram stick and the speaker went beeping 3 times (1 long,2 short),
when i tried to restsrt,
when i put the ram again, the speaker stops
i can not figure out what is hapening ,
the problem is that the normal start up of the bios is not booting,or may it is booting but i can not see it because there is no diplay ,and above all there are no normal bips comming from internal speaker(the only time it beeps is when i take the RAM off, to tell me that it is off.
    Problem Solver:
  • 6 Answers
This can be caused by a number of issues the leading being RAM (no post beeps at all). before you do anything else pull all existing RAM and install a KNOWN GOOD STICK in their place and try again.if that doesn't work try resetting the mb (see the owner manual on how to do that) bios settings to defaults (this generally selects onboard video). if you have an installed video card within the system also remove that (even though you aren't using it). is that memory compatible you have there with the board? if its too slow the stick may be fine but mb may not "think" so. do you have keyboard "flash"? is the hard drive indicator constantly lit? how about cdrom drives and/or floppies? can you eject same? all this points to incompatible or "bad" memory as the main culprit.
Posted on Dec 12, 2008
Posted on Jan 30, 2010
2 Suggested Answers
  • 95 Answers
Are you sure the onboard video is working? Try an external card and see if this works. All the beeps when you remove the memory is good because you know the processor is working.Are you sure you have the right memory? Some machines won't boot or anything when you have the wrong memory.
Posted on Dec 13, 2008
32 bit or 64 bit?
Here are the motherboard's processor specs >>>>
Intel Quad-core CPU Ready
LGA775 socket for Intel Core 2
Extreme / Core 2 Duo / Pentium D / Pentium 4 / Celeron D
Compatible with Intel 05B/05A/06 processors
Hyper-Threading Technology ready
64-Bit Processing Technology
Yes the motherboard can be used with a 32 bit or a 64 bit processor.
Nov 13, 2009 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
Please Give me freeDownload Procedur P5B-MX/Wifi-AP Motherboard Driver
Here is the direct link to EVERY driver for your motherboard free of charge. CLICK HERE
*Your vote is highly be appreciated. I hope this will help you. Drop me a comment if you still have problems. I will help you.
Jan 05, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
Dec 13, 2008 | Computers & Internet
If you just bought it, I suggest you contact the store where you bought it to claim the warranty.
If you keep trying to find solution, you might do something that void your warranty.
Dec 12, 2008 | Computers & Internet
Asus p5b-mx motherboard no display no beep
when ever you are getting the beep messages after you remove the ram card and connecting the tower to the power cord it shows that mother board is functiong normally so no problem with the mother board .try this steps so that it may resolve the issue.
1. No Boot:
. Check the cables
. Check with the socket on the wall as well as surge protector
. Swap the power cable with the monitor
. Power drain ( after removing all the cables press and hold the power button on the tower for 10-15 sec and the re-insert the power cable and connect the monitor and check)
Monitor does not power on
Check with the power cable
Check with the cable from the monitor
Swap the cable
Power drain
If the cust gets the power on the monitor and even the tower but still if he cannot view anything on the screen
Dec 11, 2008 | E-Machines eMachines Desktop PC
Asus p5b-mx motherboard not showing display but every thing is on
Hi camlamm, check out Asus CPU supported list link;
See if your CPU is in the list.
Bios not booting? If you are receiving any display on your monitor the trouble is not the graphics card. Suggest you clear the cmos jumper. See page 1-26 instructions your manual. This Asus board is warranted for three years. If nothing gives you access to the bios, suggest you call Asus tech, M-F, 8:00AM to 5:00PM EST at: 1-812-282-2787.
Good luck camlamm!
Thank you for using fixya.
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
On Asus p5b-mx motherboard no beep no lcd no bios only fans and l
Check your Video Card. Perhaps Bad driver or a malfunction
On barebone asus p5b-mx 1st try won't boot display but led is on
Hi There,
Disconnect the hard drive ribbon cable from the mother board and try again. carry on disconnecting each component at atime and trying again. Leave the video attached. this is going to be a process of elimination. sooner of later you will find out where the problem is.
My personal feeling is that the hard drive is connected incorrectly.
Let me know if you want further help.
Dec 09, 2008 | ASUS P5B-VM DO Motherboard
The problem - I guess - is that this CPU is not recognised correctly by the board. To solve it, just update to the latest BIOS, using either AsusUpdate or manually from
Dec 06, 2008 | ASUS P5B Deluxe/WiFi-AP Motherboard
Computers & Internet Logo
576 people viewed this question
David Payne
David Payne
