Question about Dell Dimension 3100 PC Desktop
Install usb2 to rs232 dongle
Hi, I've installed the driver but the dongle is not being recognised. I get message "No available COM port" when I try to download from the PC.
I'm running XP.
  • RJB45 Dec 15, 2008
    I've tried it the Dongle in both front USB ports. Should I be trying any at the back of the PC?
  • 3 Answers
Driver is not supporting the window version
or the port is not working properly
Posted on Dec 12, 2008
ASUS 990FX USB2 PROBLEM
Disregard.Just make sure Windows XP is updated. I've gotten them as well, even though I was certain the ports were all USB 2 on ASUS.
I'll keep a watch to see if anybody else posts differently.
Nov 09, 2012 | Computers & Internet
Loaded autodigitizing onto our new computer with Windows 7. Everything loaded just fine but when I try to open program it does not recognize the dongle.
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
Feb 09, 2010 | Husqvarna Designer I
I need a driver for a husquvarna 3D reader/writer card, where can I find one
Dongle issues - http://www.husqvarnaviking.com/global/8588_4197.htm
Good luck.
Dec 10, 2009 | Husqvarna Viking 1
Konica Minolta DiMAGE Scan Dual IV Film Scanner driver in an IMac
DS Dual 4 even works with SnowLeopard on a CoreDuo MBP. But it doesn not support Autofocus when used under USB2. You have to use a USB1.1 Port, if you want to use autofocus function. Every time the software crashes, because you tried e.g. to use autofocus with USB2, you will have to close the application, go to the folder User/Library/Preferences/DS Dual4/... and look whether there is a file name something like "MFSlib...." and pull it to the trash bin. You can start the application again. PS.: Your keyboard USB port is a USB 1.1 port!
Jul 06, 2009 | Konica Minolta Dimage Scan Dual IV Film...
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Modem not detected
install the drivers first, then try a different usb port, you may need to have a usb2 usb port to get it recognised
Aug 21, 2008 | Computers & Internet
I am trying to locate the usb port on the nikon 950.
the 950 has no USB connection, its pre USB, there is a rs232 serial port but it is incredibly slow.. i mean really slow.. hours to download a 64mb card.. its the headphone like socket under the rubber flap on the edge near the shutter button. If you don't have a cable getting one may be a problem these days
By far the best way to get pictures downloaded is with a CF card reader available from almost anywhere and would download your images in seconds over usb2 and wont need special drivers.
Happy snappin
Jun 08, 2008 | Nikon Cameras
Cannot install TASCAM US 144 driver
Go to device manager and verify that the ports are powered. Windows has as a default that if no USB is detected after a prescribed time, that they be powered down. (Without notification, I might add!) I would then change the parameters to where they are manually turned off and on to help the situation...accordianman
Apr 02, 2008 | Tascam US-144 Sound Card
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
It sounds like your Windows XP might be missing the USB2 drivers. Try going here http://www.windowsmarketplace.com/ and download the driver needed and see if that fixes your issue.
Sep 27, 2006 | ASUS P5LD2-VM Motherboard
Dell Dimension 3100 PC Desktop Logo
99 people viewed this question
Alun Cox
