Question about HP Compaq NC6400 Business Notebook
Disabling the touchpad on HP 530
The touchpad on the system HP 530 suddenly started acting up, an so i went to get myself a USB mouse, but the problem remains.  I noticed that when its running on battery the touchpad works okay, but once i plug in the adaptor (charger) after about a minute or two, it just starts misbehaving.
So i want to disable the touchpad and stick to the external USB mouse at least as an interim solution, any help please.
  • olaz100 Dec 12, 2008
    Well - i disabled it, wasn't called Synaptics input device though, but rather PS/2 mouse or something like that, thanks.
    I do think it is probably having a motherboard issue also, i haven't concluded on that yet, but you suggested a bios upgrade, i could try that but what i dont get is why a device that has been working for like a year + would suddenly stop working and y it would need an upgrade, its been working fine. Updates should only be needed when a new device or software or os or the likes is installed, dont you think so?
  • Greg Wilkins
    Greg Wilkins May 11, 2010
    I just want to make a suggestion. Everybody just jumps in there and tells everyone to do bios upgrade but if you can't get the exact one you need you can totally disable your computer. Everyone here just uses that for a quick fix like there is nothing to it. Just beware.
    God Bless Greg
    Problem Solver:
  • 14 Answers
Go into your windows device manager.
Search for your touchpad (should call synaptics input device)
give it a right click and disable the device.
I rather think that your mainboard is having problems, tried a bios upgrade and the latest drivers yet?
Posted on Dec 12, 2008
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
Is there a way to disable jus the side scroll bar on my gateway laptop touchpad without disabling the mouse itself? on my touchpad if my hand jus gets in front of the touchpad it scrolls and makes my...
yes. its in the control panel under mouse properties. Look for the advanced properties, theres alot of settings you can change there for the touch pad. There might be a link to the program in the start menu too.
May 15, 2011 | Gateway Keyboard/Mouse
How to enable touch pad operation in ubuntu 10.04
Ubuntu provides configuration of the most common touchpad options in System > Preferences > Mouse, under the Touchpad tab.
Try the touchpad after unchecking the Enable mouse clicks with touchpad check box.
Check operation after Enable horizontal scrolling is checked. This may not have been the default setting.
Disabling Touchpad while Typing
  • Go to System > Preferences > Mouse > Touchpad and uncheck 'Disable touchpad while typing' and 'Enable mouse clicks with touchpad'
Feb 15, 2011 | Dell F3534 Touchpad
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
How do I disable double-click on an HP Pavilion dv4 touchpad?
Hi there Dublin. I recently bought a HP laptop myself, and I believe I can help your situation, or at least I hope I can. Here's what you do: Access your Control Panel>Click Mouse>Click Device Settings>Click Settings> Click Tapping> Click Disable Tapping. That should do the trick. You are not disabling your touch-pad, just the double-clicking that is associated with it. Drove me nuts for about a day, 'til I figured it out..Hope it worked for your notebook.
Apr 06, 2009 | HP Pavilion dv4000 Notebook
The touchpad
First reinstall your touchpad driver if its program doesn't work then open the driver software and there will an option for disabling the touchpad.
Nov 27, 2008 | Dell F3534 Touchpad
Touchpad is not working properly
You can have a USB external mouse pending the time you will be able to have another touch pad because the touchpad is bad and it will be replaced with another one for proper functioning ok
Rate this solution.
Oct 30, 2008 | Dell Computers & Internet
I need to disable touch pad and use a usb mouse
Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
Sep 26, 2008 | Toshiba Satellite Pro 4600 Notebook
Disabling touchpad
dmusick,
  • Goto Start -> Control Panel then double click on Mouse
  • There you will find the to make disable your touch pad.
  • Also there might be a key (button) near touch pad this key toggle your touch pad on/off.
Thanks
May 18, 2008 | Computers & Internet
HP Compaq NC6400 Business Notebook Logo
2,908 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
