Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
How to increase water level in my frontload
Wacher - Bosch Nexxt 500. It doesnot wash as well as I expected. I have filling that adding one or two glasses of water will make the difference, because the things inside during washing cycle is almost dry. Is it difficult to adjust water level by yourself?
  • paskettj May 04, 2009
    From day 1 (over a year ago) I suspected my Bosch Series 300 Nexxt wash machine was defective. It doesn't seem to add enough water to the wash cycle. My clothes are not any cleaner than my top loading $200 whirlpool. Is there anything I can do to add more water to the wash cycle? I don't even see water durning the cycle, let alone suds from the detergent. I should at least see a bubble or two during the cycle?
  • Anonymous Mar 25, 2014
    high level water
    Novelist:
  • 116 Answers
The water level is not user adjustable but if there is a problem then the analog pressure switch should be changed.
Posted on Mar 11, 2007
SOURCE:
I can't get my bosch nexxt 500 washer to wash in cold water - even when I turn off hot, the washer won't fill
Some washers mix some hot water with the cold during filling to dissolve detergent. I had to learn that too!
Aug 02, 2013 | Washing Machines
Water won't fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Nov 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water is no fill in mashine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Aug 31, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The Softener is not going through.
you need to take the soapbox out and clean thoroughly. Pull the soapbox out to the point where you get resistance and the you will see a tab you press to release it fully. Do not force the soapbox out. Take it to the sink and clean with hot water. Softener can be like jello when it drys and will block the release.
May 24, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch machine is filling with water when not on! is this a valve or water intake part problem?
Not alwys fill valve fault.. make sure not draining back from sink back into mach,,if yes put drain hose higher to cure...
Sep 08, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch washing machine will not fill, spin, drain..has power and water to machine...perhaps circuit board?
If it won't fill it may not spin or drain unless the water level switch is bypassed. I would check the water valve & the water level switch and tube from level switch to tub must be air tight no holes.
The water level switch must kick in to agitate. I'm not sure on Bosch but some work like this..
Jun 09, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Adding detergent/softener/bleach
U cud, but not recommended as it cud lead to oversuddsing, causing all sorts of prob's.
Stick to recommended doses.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch 3.81 cu ft Nexxt 500 Plus bleach not dispensing
We had the same problem with the bleach dispenser. It was under warranty so Lowe's sent a repairman that replaced some part in the control panel that he said was faulty on this model. He also said to only use 1-2 Tablespoons of HE detergent and leave the door open. Also dilute any softeners before adding them.
Sep 13, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
905 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
