Cs-2114 all dark copies
Hello
Thanks for your suggestion. I restarted the copier and copied normally, exc. for flashing message. Ruined my whole day yesterday thinking I screwed it up. I don't have a tech manual to follow any instructions. Do you have one for this copier? I'd be glad to pay for a xerox copy. I ordered some developer. Do you think if I put in new developer, the flashing "replace unit" light will go off??
  • Everett Lin May 11, 2010
    sorry I can't give you the service manual, that against businese spirit, tell me what is the message you have right now?
    President:
  • Office Equip... Master
  • 990 Answers
If you replace drum meanwhile you have to replace developer too, after you replace then you have to simulated follow these steps;
1, power off,hold down"print"&"stop/clear" key while you turn on.
2,press"stop/clear" key within 2 second.
3,enter 60, press print,pess "'stop/clear" key
4,enter 73, press print, enter000000 press print
5, mode 1, enter 03 press print mode 2 & 3 all enter0 press print
Posted on Dec 15, 2008
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
Minolta cs pro EP3000 copier. The copy is too dark even on lightest.thanks
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
May 13, 2010 | Office Equipment & Supplies
Copies too dark
Hi Scottie,
Please clarify if the darkness is like a darkened background or like streaks across the page... If it is the former you will just require a clean of the optics, if the later then a drum cleaning blade will probably do the trick...
Please let me know if I can help further johno@execs.com .
Oct 25, 2009 | Copystar CS-2114 Copier
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Copy star cs2114
C-30 means scanner motor problem.
If there is no continuity on the motor coil - replace with a new one
The home position switch may be disconnected, or defective test for continuity, replace as needed.
check for scanner pylly bindng, and lube scanner rails with light oil.
Good Luck!
Feb 28, 2009 | Copystar CS-2114 Copier
Code 78 makes all black copies.
when in the simulation mode you have to follow the instruction, otherwise you going to screw up whole machine, try to turn off the power and on again, see what happen.
Dec 11, 2008 | Office Equipment & Supplies
Mita cs-2114 copier with flashing "replace unit" light
after you see "---" within 2second press"stop/clear" again thenyouwill see"00" show out then enter 60 press print
Dec 09, 2008 | Office Equipment & Supplies
Flashing
turn off the power , hold down "print" &"stop/clear" while turning on power. now within 2 secund, press
'stop/clear" key again, now enter78, press print let it run, will be automatically stop running, when they stop running press "stop/clear" to end the simulation.
Dec 08, 2008 | Office Equipment & Supplies
CS-2114 Problem
"Our copier started blinking replace unit" you need to replace the PROCESS unit...not the toner, and you surely don't need to go pokng around the back of a live copier with a multi-meter!!! I just relaced one for a customer, they are the blue things where you open the front door. They were available in june of '09, e-mail me and I'll get you one (don't know price off-hand) and tell you how to reset the unit once replaced.
hanks
Oct 30, 2007 | Copystar CS-2114 Copier
66 people viewed this question
jasbo
jasbo
