Question about LG 42PX5D 42 in. Plasma HDTV
Vision pts-4241 42'' plasma tv
I there looking for some parts for my plasma as named above y&x sustain boards would you know where i could buy them from please.
thanks shane
SOURCE: Conwa 42" PDP Plasma TV with Orion PCBs
I have one and have been told the main board is not working.
Cant get parts. Do you want to sell your main board.
Posted on Aug 09, 2008
SOURCE: HP 42" Plasma
I do not have a manual, but HP just replaced my Y Sustain board on my PL4260N (Model (ED429AA).
HP replaced it free because of a known problem with something they call "Plasma Mal-Discharge'.
The part number on the work order is 1032298-HS.
This did not fix my pixilation lines across the top.
I have been told that my Y-DRV is probably bad, but I need to pay for that replacement.
But, they did not verify that it is bad and did not guarantee this is what is wrong.
Posted on Oct 16, 2008
vision 4241 screen gone black sound and power up perfect any ideas anybody
Posted on Dec 05, 2008
SOURCE: Y Sustain Board Replacement
I found the Z Sustain / Y Sustain (P/N: 6870QYC004A 6870QYC004B 6870QYC004C 6871QYH039A 6871QYH039B 6871QYH039C) here for CHEAP:
I found the X Sustain (P/N: 6870QZC004A, 6871QZH044A, 6870QZC004B, 6871QZH044B, 6870QZC004C, 6871QZH044C, 6870QZC104A, 6870QZC104B, 6870QZC104C) here:
These are also compatible with the following brands according to Discount-Merchant:
Posted on Jan 14, 2009
SOURCE: X and Y Sustain Boards
How is the picture displayed? Distorted or dim?
Posted on Oct 05, 2009
Plasma tv no picture no sound blown fuse fs2
The problem here is you cannot even find that---I suggest you either buy the y sustain board as only circuit boards are sold and NO parts themselves or take it to a shop for an estimate.
May 13, 2012 | HP PL4260N 42 in. Plasma HDTV
Samsung 50" plasma HPS5033X/XAA shut off and will
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
No video but audio is fine on Sanyo 42" DP42746 TV
If you unplugged the Ysus board, then you need to replace the Ysus board, or both sustain boards. This is the part: The part is often available on Ebay, or from manufacturer. Look also at Vance baldwin or Partstore. To do a good job the Sustain boards should be tested by a tech , following service manual. It is almost for sure sustain board by the way.
Oct 12, 2009 | Sanyo DP42746 42 in. Plasma Television
56 inch tv with double vision and has bowed picture at top and bottom and color is way off
OK the bowed effect is an IC that controls the picture It replaces the flyback transformer of older TV's ( some plasmas still use transformers) Standard TVs nearly alsways have them
Doubhle vision ( ghosting is bad convergence)
Color variances Control caps on sustain or main color board.
Now these controls are spread over the two sustain or color board/s
Now some think that replacing these boards will fix their problem and many are right( at least for a while) But there is a penalty for DIY without knowing what voltages should flow from the control board to these parts. ( after all something caused it in the first place and it can be hard to find what was the offender)
There is also the tuning of the convergence and getting the picture to display correctly ( generation of TEST pattern to get this right)
If you have the skills understand electronics and have acess to the right tools it can be a cheap option to fix it. But My advise is call a professional. That way you avoid HT electric shock Radiation from the rear of the tube and extra expense from a further failure a bit further on.
Boards cost about 2-300 to buy serviceman charges about $450 with parts and tuning.His/her work also carries a guarantee
Please rate our help to keep the service online++++Thyanks for using Fixya
Sep 21, 2009 | Televison & Video
Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Jun 27, 2008 | Philips 42PF9631D 42 in. Plasma Television
Goodmans pdp42tv006 plasma,comes on for 15 secs then shuts down power led blinks red constantly until power is switched off,when power restored does as above many thanks if you could shed some light on it,...
This is a common problem on these plasma TV's. The problem resides in the high voltage boards known as the X and Y Sustain boards.. You can purchase them here for a very reasonable price:
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
To test which board is failing, you need to check voltage input to the YSUS board first... Input should be 120V from Power supply, output should be above 250V.. Do this test with XSUS disconnected. IF 250+V exists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Mar 21, 2008 | Televison & Video
HP PE4200N Plasma TV
This problem is caused by something called a YSUS board going out. You can buy the replacement parts for about $300 dollars or there is a company that will fix the YSUS board. I don't have instructions yet for removing the YSUS board, but if you've got the skills or know someone who's good with electronics, you can fix the board for about $120. I've got the same problem with my 42 inch plasma TV. I called PTS Electronics today at 812-824-9331 (their website suggests you call 800-844-7871). I spoke to Kelly. She was very helpful, but said anybody at their number can help.
Kelly said that you do not need to call first to get a return authorization. To get the YSUS Board fixed, you need to remove yours and send it to the following address:
PTS Electronics
2000 S. Liberty Dr
Bloomington, IN 47403
When you ship in, you should include a letter with the following information:
Your Name
Your Mailing Address
Your Phone Number
Payment info for the $122.60 to repair the board. If you want to pay with a credit card, note that in your letter and that you want them to call you. They'll call you to get your credit card info when they receive your board.
She suggested shipping via UPS and insuring the part when you ship it.
I learned some new things when I spoke to her. If you'd prefer to replace the board in your printer, you can use one of the following alternate parts to replace the YSUS board:
Part made by LG - part #6871QYH053A
Part made by LG - part #6871QYH053B
Part made by Toshiba - part #75003031
Out of the three alternate replacement parts, the only one they currently have available is the Toshiba part. They have it listed at $254 (I thought Kelly said $268 - maybe with shipping?) with a core value of $65 that you'll get back if you ship them your broken part. That leaves you paying roughly $200. Having them fix my part seems like a better option to me. Kelly also said that all these parts for the HP TV are refurbished parts - none of them are new - that's why they want you to send them your broken part.
Link to PTS website with information about ordering 1032298-HS ( They currently have 0 available for sale. The message on this page tells you to contact them to arrange repair using the information provided above.
Mar 18, 2008 | HP PE4200N 42 in. EDTV Plasma Television
Auto st-by after 1hour
more likey you need parts lit for this set.It includes YSUS.XSUS and Main power board.I will get back to you on this for part number.You will be amazed on price..
Dec 03, 2007 | Sony PlasmaPro FWD-42PV1A/S 42 in....
LG 42PX5D 42 in. Plasma HDTV Logo
82 people viewed this question
Computer Repairing
Computer Repairing
