Question about HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply
Blinking green light on Bestec ATX-300_12Z rev BD
All same symptoms as posted by bkenn 0n 2-12-08 additionally noticed that the light shifted to seady if the 24 pin connector to the motherboard was unplugged. This cause me to hesitate just a bit in thinking that the power supply is the problem. Just maybe the motherboard is the cause ???
Your quick assistance will be appreciated.
- Bruce Gram
  • 3 more comments
  • Martha Kile
    Martha Kile Dec 31, 2008
    I am having the same problem with mine. I also thought it maybe the power supply. Anyone know what it could be?
    my email: marthakile2000@verizon.net
  • Anonymous Jan 22, 2009
    Hi. Model ATX-300-12Z Rev. BD. Clicking sound, fast green blinking light. If connector to motherboard is unplugged, light stays green. Tried another non-compatible powersupply, computer on/off switch did activate that power supply, so I am "guessing" power supply is faulty. Will try to locate similar and replace. Did you find replacement? Where?
  • Anonymous Feb 04, 2009
    i left the computer of with the power supply of for 3 weeks and when i turned the power back on the computer will not start and has a blinking green light in the power supply i took the covers of and checked all connections they look ok so how do i get tis repaired thank you for your help
  • Anonymous Feb 15, 2009
    mine did the same thing. i'm going to go buy some cheese at the market and see if that helps.
  • Anonymous Feb 24, 2009
    Left computer unplugged for a couple of hours then when I plugged it back in...power supply light started blinking.
It has a blinking lite whats wrong
Posted on Sep 08, 2010
Does a solid green light mean the power supply is ok when disconnected from motherboard and drives, ATX-300-12Z
Not necessarily. The green light usually just signifies power to the power supply. Amazon sells a cheap power supply tester that can verify everything on a power supply from old to new.
Jul 21, 2014 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
My computer will not turn on we had a power cut and the computer was running at the time power didnt come back till morning now and there is a blinking green light that use to be a solid green light
The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue.. Many computer shops will test for free.
Sep 06, 2011 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Bestec power supply model ATX-300-12Z Rev BD green indicating light flashes on off when plugged in.
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Jan 06, 2011 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Feb 16, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
The pc wont power up and the green led on the PSU is just flashing, is the bestec atx 250 12z broken?
Most likely yes.
I would also reccomend an upgrade to that PSU when replacing it.
Something in the 450-Watt neighborhood is usually a bit more robust.
Oct 15, 2009 | HP ATX-250-12Z, ATX-250-12Z REV.: D2, HP...
Bad power supply?
Do yo have a volt meter or an atx psu tester?
you can check voltage to see
If a power supply is bad, your pc will turn off or/and turn on and turn off. As long as your system is running without and shut downs your good.
However if your pc is turing off, I would change it as soon as you can. basically what is happening, when you unplug everything there isn't much of a draw on power so the light remains steady, but when you plug devices in there is a draw and the PSU cannot deliver.
I hope this helps.
Sep 07, 2009 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Flashing Green Light on Power Supply
get yourself a themaltake ps
make sure you remove the old one and take it with you to the shop or get the shop to do it for you if you dont have the expertise yourself.
hope this helps
Dec 31, 2008 | Compaq 300Wt Presario ATX Power Supply...
System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Jan 02, 2007 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply Logo
2,586 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
