Question about Maytag Neptune FAV6800AW Top Load Washer
Can't get washer to finish spin cycle
Shortly after the spin cycle starts, I get a can't spin or unbalanced load error. There is also a few inches of water when I open the lid. Spin cycle works fine if the washer is empty or I wring out all the clothes and drain washer, then replace clothes. Not exactly what i spent all that money for...
  • 5 more comments
  • Shawn Roberts Mar 25, 2007
    Since the washer was still under warranty with Sears, we had a repairman come out. He replaced the clutch, pressure switch and tub displacement sensor. The machine runs well now, and is noticeably quieter.
  • Anonymous Mar 14, 2014
    the washer will not go through an entire cycle without becoming unbalanced. happens regardless of load size or spin speed.
  • Anonymous Mar 15, 2014
    spin light on but water wont come in washer and lid load light on
  • Anonymous Mar 18, 2014
    water does not drain completely. when restarted you can hear water draining but as soon as it start to spin it flashes a Uc code. re-distributing the load does not help.
  • Anonymous Mar 23, 2014
    washer started fine ,washed clothes, drained water but when it was time to spin , washer just stopped and the spin light stays on
  • Anonymous Mar 29, 2014
    washer will spin and drain water but will not go into high speed spin to wring out clothes. Load is balanced. It won't spin fast even when empty.
  • Anonymous Mar 30, 2014
    IT DOESN'T WANT TO SPIN OR DRAIN THE WATER OUT OF THE CLOTHES
We have the same problem, machine constantly goes out of balance. Repair guy came buy and said to make sure we wash a full load. The machine was working fine until a few weeks ago, we wash about 2-3 loads a day. Repair guy said all systems checked out ok suggested it was our problem (user) also said there might be a recall but all I can find is the recall for front load neptunes. My suggestion is to either return the machine or never buy it.
Posted on Apr 28, 2007
I have the same problem they can not fix it so dont waste your money on a repair guy they just run it through a dianostic test and tell you that you are no using the machine properly
Posted on Mar 14, 2007
    Problem Solver:
  • 16 Answers
I'm not familiar with this washer, but if there is water in the drum when it comes to the spin cycle chances are that it won't spin. The likely cause of water left in the drum would be that it is not emptying fast enough, so you might check the pump for a blockage, or if there is a filter check that for some obstruction like fluff, coins, or small items of clothing which can sometimes get drawn through from the drum. Tom.
Posted on Mar 09, 2007
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
My washer's digital time screen changes from the time remaining to a symbol that looks like "UL".
This error code indicates that an unbalanced load is detected.
Click the following to learn more about unbalanced loads in the BravosTM washers. The example is for an impeller washer but is applicable to washers with agitators.
Is the wash load balanced?
If the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause.
Is the washer level? Does the washer rock when pushed against the corners?
If the washer is not level, the washer may be more sensitive to unbalanced loads. The washer must be level from side to side and from front to back. The front and rear feet must be in firm contact with the floor. Make sure the locknuts are tightened. See the Installation Instructions for details.
To remove the error display, press Power/Cancel or Pause/Cancel once.
Jan 02, 2011 | Maytag Bravos MTW6600T Top Load Washer
Error code UL with 12 minutes remaing on each load
hi,
if the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause.
If Power/Cancel or Pause/Cancel does not work
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start/Pause.
Sep 06, 2010 | Maytag Bravos MTW6600T Top Load Washer
Unbalanced load- spin cycle stopped . cannot get machine to start
Hi just read your posting .Do you still require help?If so reply back and I am sure I can help you.
Jul 12, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washer does not finish cycle..it stops at spin and it displays a 'dc' code...what is this
The Service Manual for reference. Sears Parts Direct for reference.
dC code from the Service Manual = Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
Your wash tub is banging around during the spin cycle correct?
You can redistribute the wash basket load until the cows come home the issue will only continue to get worse. Maybe start throwing uC error codes to the console display for continuous unbalance error code.
Your FAV6800A or FAV9800A has a Clutch malfunction. It can be corrected if you are handy see this DIY fix Clutch Fix. post.
If you decide to dive in I will help you through the fix………Rich
Feb 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
352 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
