Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
WATER WILL NOT DRAIN HOW MANY YEARS WARRANTY DO I HAVE??
I HAVE TAKEN THE INSIDE OF DISH WASHER APART...
RAN GARBAGE DISPOSAL FOR 3-4 MIN.
CHECKED ALL AREAS THE MANUAL TALKS ABOUT WITH THIS PROBLEM ANY OTHER SUGGESTIONS???
SHOULD I CALL??
I DONT WANT TO CALL IF I DONT HAVE A WARRANTY!!!
    Sergeant:
    Champion:
  • 291 Answers
It has a drain pump that pumps the water out when time to drain / replace it it should fix the problem
part number is WD26X10016
Posted on Dec 12, 2008
Dish washer wont empty out leaves about 2 or 3 in in it
Drain hose clogged or Not ran in the proper draining position, under the sink where the hose ties into the drain system or garbage disposal, the hose should be higher than the connection point, I have fixed this by tie strapping hose to the bottom of the counter or sink, hope that helps ?
Feb 27, 2015 | Kenmore Dishwashers
When my dish washer discharge water instead of the water going out the drain it come out the overflow valve.
The dishwasher usually drains into disposal, or directly into tailpiece, and water drains down to the p-trap.
Trap may be clogged or stopped up.
Clean out drain line, tighten connection where dishwasher attaches.
Clean out bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Oct 18, 2012 | Kohler K-692-7 Clairette Kitchen Sink...
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Disherwasher wont drain out water.
Will the dish washer spray water during the wash cycle? If no it could be the pump motor. The motor will run in the opposite direction to drain the washer. If it spays water it could be a clog in the drain hose or the connection to the drain (on newer units) or garbage disposal (on older units). Remove the hose from the drain and place it into a large bucket to see if it drains during unit operation (stop the washer if the bucket fills). if it does clean the connection to the drain or the garbage disposal hole. If not make sure the hose is free from obstructions. If the above checks out then check for voltage on the pump connection with a volt meter. You may be able to visually inspect the pump or listen for the vibration of the pump during the draining operation. If you have voltage the pump is defective or the internal garbage disposal (found on newer units only) is clogged or damaged.
Jan 13, 2011 | Dishwashers
After wash cycles are completed there is about 1/2 gallon of water remaining in the bottom of the washer. I checked the drain that exits into a disposal and that is clear. All around the bottom of the...
Hi and welcome to FixYa. I am Kelly. Most dishwashers are connected to the sink / garbage disposal via an Air Gap. The Air Gap gets debris inside it that blocks the drain passages. Check out this video on how to clean it:
Jul 01, 2010 | Maytag 24 in. MDBH950AW Built-in...
Dish washer will not drain
What I did was replace the 'magic drain' on the sink- u know the back flow value that drains to the disposal. solved it-
Jan 07, 2009 | Dishwashers
My Kenmore Elite UtraWash Dishwasher won't drain completely. We have checked the hoses (water supply and drain connected to the disposal) - both are free of obstructions. We have taken the whole thing...
I have the same problem. The part you're talking about can be released from under the dishwasher to clean it. www.searspartsdirect.com has useful diagrams. I cleaned everything but still have the problem which is caused either by the "check balls", the "check valve" or the "pressure check" thing. I still have to figure it out. A good way to know if the system is obstructed is to press the drain button when there is some water left in the bottom.
Dec 01, 2008 | Dishwashers
Dish washer does not pump out water after rinse or wash
Check flap valve and solenoid-Check for hose kinks or food clogs-Check pump impeller for damage-Check-timer Check the (check-valve flapper) some models have a check valve located where the drain hose attaches to the dishwasher.If you just installed an garbage disposal check the knock-out plug at the connection.Check that the pump hasnt gotton stuck due to lack of use or gunk in the pump. 3 things 1-You can remove the lower kick panel and turn the fan blade on the motor until it turns freely 2- Boil a big pot of water and pour it into the tub part let it stand for 15 to 20 min then try the dishwasher 3- Or my (FAV) duct tape your shop-vac to the waste hose and try to blow or **** out the stoppage. Rice is a big problem and pasta for dishwashers and thanks for the advice on my car I will try the method,and sorry about the comment
Nov 21, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dish washer
The drain in to the garbage diposal is clogged.  Remove the drain hose from the dishwasher and clean the hose.  Also check the inlet to the garbage disposer and clena it.
Oct 28, 2007 | Dishwashers
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
