How do I put the nob back on the wall heater?
How do I put the nob back on...seen easy...however it does not fit back on....did I loose a part? Please help.
  • yesllc Dec 13, 2008
    yes I got the clip...one end is around and the other end is shape like a D....and the D goes into the nob....except the other end O does not seen like it fit into the wall heater...there another panel under the cover that it shape of old style door hole....it would not fit. pls help...
  • Anonymous Dec 13, 2008
    nob fell off the wall heater....there is no spindal coming out of the heater...there is only a screw
    like...that one end is shaped like a D and the other end is should like
    a nut/screw....and what on the heater panel is a hole shape like a old
    key hole...model K304A...pls help
  • Heating & Co... Master
  • 3,081 Answers
Some times there is clip that goes in the knob shaped like a D that could have fell out , is called a D clips sounds silly i know might be that simple ,
hopw that helps
Posted on Dec 12, 2008
  • Paul Carew Dec 13, 2008
    is there a spindal coming out of the heater which the knod fits on too this should also be d shaped ?
    try www.marleymep.com/ they might be more help they do a on line tech guy
    hope this helps
I have a 2014 Chrysler 200 and my and my blower nob when i turn it on won't work on high sometimes or on low. I have to keep turning the nob and it feels loose
Need to replace heater control panel. The knob is a resistor type. It's just worn out and broken. I have seen this happen many times
Nov 26, 2017 | Chrysler Cars & Trucks
One of the nobs on the front of my gas stove is broken and i would like to know where i might get a replacement on ? the burner still works if i push the nob back on and turn it but it is broken in half...
Hello Danny, I have seen replacement knobs at Home Depot and Lowe's Hardware. Write down the make and model number of your stove and take a knob with you to compare.
Mar 24, 2015 | Kitchen Ranges
My 2006 Aveo is leaking from the firewall side of the engine. impossible to see where its at. Please advise
Your talking antifreeze i asume if so its an issue with the heater core. If the heat still works good then it mabey a loose hose clamp on the out side of the fire wall witch would the best thing . If the cord is pluged it would cause this . Do you smell antifreeze with the heat on if so you likely have a hole in the heater core it self witch it needs to be replaces witch is not usely an easy job in most cases seeing that most of the dashboard needs to be removed to get at the core. However if it is a clog you may be able to clear it . You will need about 3 feet of 5/8s heater hose cut it in half so you have 2 peices about a foot and a half long . Remove the heater hoses from the out side of the fire wall and plug the short hoses on the nipples . Get a pot on pan something that will fit into the space and with a garden hose with a nozal gentley start forceing water back and forth between the two hoses and catching it in the pot not to much pressure at first and see what comes out . Then get the whole radiator system flushed and put new antifreeze in it . Antifreeze lasts about 5 years contaray to popular belive that it lasts forever and you just need to add to it. Its a 2006 do it now and it will save you later Good luck hope you don't need a new heater core
Apr 26, 2012 | Chevrolet Aveo Cars & Trucks
Pilot light on hot water heater is out
you need to shut off the the red nob and turn the nob off in front take the cover off remove the heat shield turn the nob on top to pilot use a piece of paper to light put in next to pilot and hold button down for 20 to 50 secs pilot should stay lit turn nob on front then burner should kick on then you should be all good
Mar 21, 2012 | Water Heaters
I can't find out how to install the cartridges`
Facing your printer,
Right below where key pad is located,there should be a nob.
Lift on the nob and you can c the cartridge is placed.
Take them out and you put back your new cartridge.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | HP OfficeJet 4215 All-In-One InkJet...
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
I don't think my pilot is lite. I need to know How to light the pilot
Hi, open the front panel of the furnace, At the bottom of the furnace you will see a gas valve with a red button, or nob of some kind. Place the nob on pilot, then push in and light the gas coming out of the pilot don't let go of the button for at least 30 seconds because the sensor will not detect flame. If this dose not work you make have a bad gas valve or a bad pilot generator.
Oct 07, 2010 | Williams (5009622) Ceramic Gas Wall...
Can I hook up a digital thermostat to a wall heater? model# 22dv3 (I pulled off the vent cover and only see one line running to the knob that I turn to adjust temp.) that wire looks like its copper...
may be not if its high voltage no but if its low voltage going to the nob well yea if it has just two wires going to the nob yes you just need a t-stat that uses batt.
Apr 06, 2010 | Heating & Cooling
Jammed deskjet 840c
IT IS VERY EASY TO REMOVE THE PAPER JAM. YOU JUST SEE THE BACK OF THE PRINTER A WHITE COLOUR ROUND NOB IS LOCATED JUST UNLOCK THAT NOB (LOCK AND UNLOCK ICON IS SHOWN BESIDE) PULL THE DOOR SLOWLY OUTSIDE REMOVE THE PAPER JAM GENTLY.THEN AGAIN FIT THE DOOR AS IT WAS AND REWIND THE NOB TO LOCK IT .DO THIS CAREFULLY AND U WILL GET SUCCESS.
Jun 02, 2008 | Apple HP DeskJet 840c InkJet Printer
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
