Question about Maytag MMV4205 Microwave Oven
My Maytag MMV4205 Microwave Oven runs but does not heat
Everything on the microwave works, except it does not heat.
  • 7 more comments
  • jon4611 Dec 13, 2008
    I have the same microwave doing the same thing. It is a Maytag MMV4205BAW. To all appearances it is working normally, the light comes on inside, the control panel "buttons" all work, the turntable rotates, and the cooling fan comes on, but it does not heat anything. Could this be a defective design or manufactured with defective parts?
  • james_dickso Dec 15, 2008
    The inside light and turntable come on and it sounds like it always has. The model number is MMV4205AAW and the serial number is 10127252GA. It was manufactured in January 2005.
  • jneubert Jan 31, 2009
    Everything works on the microwave except it will not heat.
  • dana123 Feb 09, 2009
    WE HAVE THE SAME PROBLEM.. runs fine but will not heat everything.. maytag MMV4205BA
  • Anonymous Feb 23, 2009
    microwave works normally as far as turntable, timer, lights, fan, etc. except it doesn't cook the food at all. Started all at once. Working fine just a couple of hours earlier & then just stopped cooking.
  • jamesdcorder Mar 02, 2009
    The microwave turns on and appears to operate normally, but the food does not "cook" as it did before. Sometimes it does not warm the food at all.
  • RJCTECH Mar 07, 2009
    I have the same problem... Model MMV420AA
    and i took it in to get repairsNovember of 07 and had a blown mag .. at that time was covered under warranty... however the problem at that point was more severe was totally dead. No sure what to do with this... Seems like this is going to be expensive to repair... Might be time to get a new Microwave and DUMP the maytag Brand!
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    Do you have the model number?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • Anonymous Mar 30, 2014
    Everything seems to work except it doesn't heat the food. The touch pad functions and so does the clock and fan, but the oven does not produce heat
  • Maytag Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
The microwave isn't heating/cooking on any setting but the turntable, light is working. What should I check before calling a repairman?
There is nothing more you can do, you have verified everything is working except it is not heating the food. The next step is have the repairman come in to isolate the cause.
Jun 02, 2011 | Maytag MMV4205 Microwave Oven
The heat does not come in the microwave, everything else works.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 26, 2010 | Maytag MMV4205 Microwave Oven
My micro wave is not heating everything esle is working . it was working find yesterday it won't heat water today
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 11, 2010 | Maytag MMV4205 Microwave Oven
Maytag mmv4205bab continues to run after time is up. The fan does not circulate, but it continues to heat.
Our microwave in office won't shut off. It continues to heat and fan is running as soon as we close the door. Tried everything, unplugged, canceled everything. Please let me know what to do.
Oct 04, 2010 | Maytag MMV4205 Microwave Oven
MMV4205 1150 Watts Microwave Oven: all boards and timers work will not heat food m...
heatman101
syjs
May 18, 2010 | Maytag MMV4205 Microwave Oven
Microwave maytag
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 17, 2009 | Maytag MMV4205 Microwave Oven
The microwave runs but doesn't cook the food. It made sort of vibrating noise and stopped heating. Everything else seems to be working.
HI. this is called Magnetron failure. you will need to replace this failed device. it is responsible for the heating of the contents.
Jun 07, 2009 | Maytag MMV4205 Microwave Oven
Once I place food in to get re-heated, I noticed that my microwave did not heat the food, even though everything else worked...can you help
time for a new one. the microwave unit is dead, no the oven. the microwave unit is the heart of the oven. so, if that goes, everything else goes.
Apr 07, 2009 | Maytag MMV4205 Microwave Oven
MMV4205 doesnt heat up
If not a separate fuse, then the hi-voltage inverter or magnatron have likely failed. The first can be $130. The second $45.
Jan 30, 2008 | Maytag MMV4205 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
1,143 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
