Question about Reddy Heating & Cooling
Reddy Heater runs but will not ignite with bonnet attached.
Heater motor would run but heater would not ignite. I took the bonnet off, cleaned the nozzel and the filter the comes from tank/line. When plugged in without bonnet, heater motor runs, ignites and heats fine. WITH BONNET ON HEATER motor runs but heater will not ignite. What is the problem? What can I do to fix it?
  • 232 Answers
First, let me say that the general principal of fuel delivery ***to the spark plug*** depends on several things.
  1. Proper air pressure at the nozzle (provided by the rotor/motor)
  2. Proper “fuel pattern” at the nozzle (provided by the rotor/motor/nozzle)
  3. Proper amount of ***air & fuel*** at the nozzle (provided by the rotor/motor/nozzle)
  4. Proper ***air flow (cfm) through the combustion chamber (provided by the fan blade/motor)
  5. Proper rpm’s of the motor, which affects all of the above.
On your heater the first step is to set the air pressure to specs. Instructions are on the www.reddyparts.com website. This pressure setting directly affects fuel delivery & fuel atomization
This nozzle rule will only apply if everything is correct as far as fuel delivery applies. The pump pressure must be correct- not almost correct. Set the pressure with a low-pressure gauge that registers12-15 psi max. A gauge with a higher scale just will not read close enough to satisfy the system. If the pressure is not correct, the above rule will not apply. Instructions for setting the pressure can be viewed at http://reddyparts.com/pressure.htm.
  • Next, if the fan is OK (correct & intact) look at the NOZZLE. DESA recommends annual replacement of the nozzle, which is a wear item. Naturally, annual usage varies, so, wear will depend on annual usage. A worn nozzle produces a cone shaped SPRAY rather than a cone shaped FOG. A spray drowns the spark, where a fog gets ignited, provided it contacts the spark. ALSO, the pattern from a worn nozzle can completely miss the spark (combustion??? Hardly!). When the top is lifted the change in airflow allows a false correction in the combustion chamber, allowing combustion, but when the top is replaced the flame is extinguished. A restricted nozzle or a restricted fuel filter will also distort the fuel pattern and create the same symptom. Also, like the fan blade, make sure that the correct nozzle is installed. Nozzles get swapped, too.
Posted on Dec 12, 2008
Rlp35 reddy heater runs few minutes flames out, fan continues to run?
clean the sensor so that the control can have confirmation of ignition
Nov 11, 2012 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My R100 reddy heater will ignite and run when I have the top of the torpedo off. While running I can put the top on and it runs smoother with less excess fuel. It does not ignite or start with the top...
The air settings may have changed. Anytime you change a filter for the air, or just remove it and reinstall it the air settings change. A small amount of pressure change can cause your issue. These heaters are very sensitve to air pump pressure changes. If you took off the nozzle, you took off the hoses too. Check that the hoses do not leak at the fittings to the nozzle body.I belive there is a sticker on the unit that gives the specs for the air pressure settings. Do you still have your owners manual? It should tell you in there how to trouble shoot the heater, There are 2 screws at the back of the motor, 1 is the pressure gauge port, and the other can be adjusted to set the pressure. It is recomended to use an air gage to set the pressure after any kind of service.You will need a low pressure testing gage. Accurate to 3-6 lbs. NOTE:( tire pressure gages are not reccomended for this) Check those lines, use a clamp or a zip tye to seal them to the fitting. I hope this helps.
Dec 23, 2010 | Reddy R155D Utility Heater
R100 reddy heater, low pressure forced air heater. the heater ignites, motor runs for 30 seconds then shuts down. photo cell good, filters clean, no ignition board, pump pressure unknown.
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Thanks
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater 55,000 has trouble igniting with top half attached
I'm assuming you mean the protective cover on the top of the unit? If so pull the back off the unit. Replace the filter. Buy a test gauge at www.reddyparts.com and set the pressure to 3.5 psi and I think your unit will run fine.Let me know how you make out.
hardrocko
Feb 05, 2010 | Reddy Heating & Cooling
Heater will not stay on rm60 reddy heater
When you say the heater is coming on does it actually ignite or is the motor just running until the safety circuit kicks it off? The air pump on you heater should blow at 3.5 to 4 psi which runs up to the nozzle which is a venturi which sucks the fuel out of the tank. The motor will generally run for 20 to 30 seconds trying to ignite. If the flame sensor does not sufficient flame during the time it shuts the motor off. Check these items and let me know what you find.
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater won't ignite
Moving mine while it was running fouled the spark plug. You can remove the top of the Reddy Heater and access the plug. In my case took less than 10 minutes and it's up and running again. I removed the top and replaced the spark plug. No problems
Jan 24, 2009 | Reddy Heating & Cooling
Reddy Heater R55 concerns
They are grounds, and should have two screws on the burner tray to hold it from moving. On my heater this is where the grounds get attached. It gives the igniter a dedicated direct ground.
Jan 10, 2009 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
365 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
