Question about Lexmark Optra M412 Laser Printer
Lexmark Optra M412
Display was not working properly and now it is diplaying a 939 service system board error.
  • 1 more comment
  • Anonymous Jan 06, 2009
    Display is very dim, same error code, and continuos beeps.
  • Anonymous Feb 12, 2009
    I turn on the Optra m412 and it says 939 Service System Board. This model doesn't even show up on Lexmark's web site.
  • zabrina liang May 11, 2010
    Can you verify the error number? I do not find a 939 error code in the knowledgebase
  • 412 Answers
Error 939 means --
RIP Communications Lost
Controller EngineCommunications Lost
The controller board and the engine board cannot
communicate with one another.
Solution --
POR several times
Check each board
for secure ground.
Replace the assys
in the following
order
1. Controller Bd
2. Engine Board
3. Intterconnect
  Board
Posted on Mar 09, 2009
935 service printer head error. how do I fix it?
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Mar 08, 2011 | Lexmark Optra M412 Laser Printer
I don't have a owners manuknow how to change the paper trays from
Go to Menu, then Paper Menu. Select Paper Source then select Manual Feeder. You should also select manual feeder from the driver.
I'd like to add the link to download the User's Guide for future reference. http://www.lexmark.com/publications/pdfs/optram410/enUser.pdf. Hope this helps. Leave a comment if you need more assistance. Thanks.
Jun 29, 2010 | Lexmark Optra M412 Laser Printer
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
900 Service RIP Softwrae on LexMark Optra T614.
any one of the boards in this printer can create this error it is a software communnications error. start with the easiest one the simm remove it power the unit on do this with each board untill you isolate which one is causing the error. cleaning the contacts sometimes fixes this problem. more times than not is a bad nvram chip on a board
Nov 23, 2009 | Lexmark Optra T614 Laser Printer
What would cause a 900 RIP code on a Lexmark T612?
Go to http://support.lexmark.com/printerfirmware
Locate the appropriate authorization code for your printer model from the following list and enter it:
Optra S (4059) series printers: 4059engn.
Optra T610, Optra T612, Optra T614, Optra T616 printers: optrateng.
Lexmark T520, Lexmark T522, Lexmark T620, and Lexmark T622 printers: lextengn.
Lexmark T630, Lexmark T632, Lexmark T634 printers: e551416.
Lexmark W812: eng204
We recommend you choose to save the file within a directory on your computer's hard drive.
Once it has been saved, go ahead and run the file. The downloaded files are self-extracting ZIP files. Running this file will create a set of .PJL files and a file entitled Readme.1st. The Readme.1st file also contains directions for sending the file over through a parallel connection.
Oct 30, 2009 | Lexmark Optra T612 Laser Printer
We have an Optra M412 that has a 921 Service fuser error. We don't know where to find the fuser
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
You can find the fuser at the back of the printer, remove the cover and there it is. It holds in two screws and a power connection. If the printer is out of warranty, your next option is to change the fuser which costs around $200, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Sep 19, 2009 | Lexmark Optra M412 Laser Printer
Lexmark Optra M412 pritner find IP address
Have you printed out the printer's Menu Settings?
Jun 30, 2009 | Lexmark Optra M412 Laser Printer
939 service system board; what it's mean.
First, make sure the printer power is off and remove the RIP board. When you turn the printer back on, the only option on the display will be to perform the test. Pressing the button next to that begins the test. The page that comes out should have just a lot of lines printed on it. If this does not print or is somehow messed up, then the problem must be with the engine board. If this page prints and looks OK, then it is probably the RIP board that should be replaced. Please keep in mind that this test cannot be considered to be conclusive but it can be used to make an educated guess about which component is failing.
When the printer beeps five times and the operator panel is blank, there are several things that might cause this. It could be the op panel, the op panel cable, the Low Voltage Power Supply (LVPS), or the engine board. To find out which component is failing, the printer would need to be checked out by a service technician and the failing component replaced by him/her.
Apr 20, 2009 | Lexmark Optra M410 Laser Printer
Load MP Feeder
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
Nov 20, 2008 | Lexmark Optra M412 Laser Printer
Lexmark Optra M412 Laser Printer Logo
1,003 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
