Question about Microwave Ovens
Microwave not spinning or heating
The GE JTP85BOA1BB is not spinning or heating it is lighting up and the control panel is working it is the same control panel for the oven attached. Can it eesily be fixed? It was built in June 1999
  • Anonymous Apr 29, 2009
    me too
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 27, 2008
ginko
  • 19396 Answers
SOURCE: we have just purchased a
First: never attempt heating pure water in a microwave, that is dangerous.
Ensure the oven is not set to the minimum power, otherwise the heating will be minimal.
Try heating some food at maximum power for two or three minutes, if it does not heat, take it back to the shop.
About water in the microwave, see here:
Microwaved Water - A MUST see
Superheating of water
Posted on Oct 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: display panel works but no heat, no fan, turn table doesn't turn
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 12, 2009
SOURCE: oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Posted on Apr 17, 2009
Fan blows when doors open
One of the three door switches has failed and will need to be replaced. You would need to access behind the control panel to check them and or replace it. Good luck
Feb 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
My 1998 ge GE JE1640GA 001 microwave, all buttons works,lights on, the problem is it will not heat,and the tuneable do no spin, please help
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | Microwave Ovens
GE model J KP85B0A3BB over range will not heat up. Both control panels for microwave and range work, interior light comes on when door opens, and glass plate will turn...
The most likely problem is the magnetron, it works with the high voltage capacitor and diode which can be a factor. The three work together to generate the high voltage that heats the food. If the repairs are done by a professional the cost will be high when you consider parts and labor.
Feb 09, 2011 | General Electric Microwave Oven
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
Microwave won't heat. turntable works control
Hi! check the fuse that goes through the magnetron because i think it is no functioning.
Sep 10, 2009 | General Electric Microwave Oven
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
GE Spacemaker - microwave works but the inside plate doesn't spin
you have a bad turntable motor or a bad control board.. start with the motor 9 time out of 10 this is your problem.. you can pick up this part at your local parts house or order online.. look for universal part. this will be alot cheaper then the oem.. just take the screws out of bottom panel under microwave. panel will drop down. you will see little round motor about 2in' make sure unit is unplugged.
May 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
194 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
