Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Suddenly stopped running// The last time it ran it did the entire load correctly// I loaded it today and all the lights that normally show light up and I press start and it then shows the washing light, but nothing is happening. No sound nothing. Please help thanks
  • 4 more comments
  • UncleanDish Jan 08, 2009
    My dishwasher (Kenmore Quietguard Std #587.16252402) was working fine until I opened it in the middle of the washing cycle and when I closed and latched the door, it would not continue(as it has a few times before.)
    I hit cancel and the LED's all went off and it did not drain. I hit cancel again and no change. I hit cancel again and the washing LED along with the other LED's that were originally set, come back on.
    I did notice that if I let it go, it would go through the motions without actually working(the LED's would change and eventually it would claim to be clean.) If I tried to start a new wash, it would go right back to stating it was in the wash cycle - go to second paragraph and continue reading ;-)
    Disconnecting power had no effect.
    How does one reset this beast(button combinations??)
    TIA.
  • nyb1982 Jan 13, 2009
  • laro862 Jan 29, 2009
    I also have the Kenmore 587.1625 model and it ran fine the last time I used it, I have only used it maybe 6 times. and tonight I loaded it and went to turn it on and it won't start. It is like there is no power. Please help!
  • amyaudas Mar 31, 2009
    I have the same problem. I have tried disconnecting and reconnecting the control panel and have also turned the breaker off and back on again. Nothing has worked.
  • lomayr May 04, 2009
    i have the sme problem all the lights are flashing but nothing works, I need a reset code
  • Anonymous May 23, 2009
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to miss_vmari@netzero.net. I would like to solve my dishwasher problems as soon as possible. Thank you!
Posted on Sep 05, 2010
We have a Kenmore Heavy Duty 70 series model 11092575110. It has been running perfect and suddenly it has stopped with a load of clothes and water. Please advise. Thanks
As power reaching the machine? Is the motor being energized ? If power is reaching the motor and it is not turning, the unit has died a noble death while working.
Sep 09, 2015 | Kenmore Washing Machines
My Kenmore moel #11027082602 ran while we were
Yes it is very possible. If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Feb 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool dishwasher stops at rinse cycle and won't go
Aureley, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 18, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Kenmore refridgerator model #50522100
Is it still working..If so it probable doesn't have a problem.My guess is that it went into the defrost cycle.When you unpluged it in 2003 it was time for the defrost cycle, so when you pluged it in it went into the cycle..
Sep 28, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore he4t front loading dryer stopped working
did you clean the lint?
is the way the airflow goes not blocked with residue??
Mar 19, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
673 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
