Question about Microsoft Xbox 360 Console
Xbox 360 system error
System error comes up on screen as soon as you turn on the console
    Problem Solver:
  • 16 Answers
Depending on the error your xbox may be repairable maybe not. If you still have your warranty (3 years from when you purchased your xbox) then send it back to microsoft, otherwise re post with the error.
Posted on Mar 03, 2009
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox 360 it turns to a black screen and says i have error E73 and when i went to Xbox.com it didnt say anything about it
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Apr 14, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Apr 07, 2010 | Microsoft Xbox 360 Console
When turning on the xbox the screen turns pink
OK did you ever try to hack your system did you open the inside of it did you drop or smash it or leave it in extreme temps if not it might be the result of poor cable connection,first turn off your Xbox 360 and check out the cables that are connected to the system. Remove them and re-connect them firmly. Now switch on your Xbox 360 again. There is a good possibility that you will find the fuzzy purple screen gone. If you still find a fuzzy purple screen then this might be a bit more complicated problem that your system is experiencing. Usually system overheating is one of the major reasons that cause various Xbox 360 errors
May 05, 2009 | Microsoft Xbox 360 Console
Xbox 360 system error problem
this should be sent to microsoft who should fix it for free
Nov 29, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
Xbox live gamer tab
well u could just try to recover ur gamertag
but i had somewhat the smae problem my 360 went to a black screen as soon as i turned it on and then it had a error code at the bottom while 1 red light flashed
call microsoft and told me they will fix it for free still havent sent it in thou -_-
Jul 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 system error E74
E74 error There is a 90% chance it's a chip problem it can also be caused by a faulty AV cable so check that first.
if nothing work call xbox support line 1.800.MY.XBOX
Dec 28, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
