Question about Microsoft Xbox 360 Console
Xbox 360 system error
The power on button keeps flashing red and a system error page comes up please help
  • 124 Answers
How many quarters of the red ring are lit? 3 of 4?
If 4, you need to check your audio/video cable.
If 3, you need to contact Microsoft support for a repair.
Posted on Dec 12, 2008
My xbox only blinks red in middle then fan kicks on and system shuts down
The red light next to your Xbox 360 power button indicates that your system has detected an error. As to what that error is you will need to follow the link below to debug.
http://support.xbox.com/en-US/xbox-360/system/flashing-lights-solution
Aug 10, 2015 | Video Game Consoles & Games
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
2 red lights on my Xbox 360 won't play any games or DVDs E-74 keeps coming up
Hello!  Unfortunately, with this error, there are no troubleshooting tips in which to apply and your system will need to be sent in for service. Visit the following link on who to send you console for service:
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Dec 28, 2010 | Microsoft Xbox 360 Console
My xbox told me error e79 and now it wont come on at all it just flashes red???tried removing the hard drive but it still flashes red and refuses to come on...help
Clear Any Failed system updates that cause the console to error.
1. With the console off, press and hold the sync up button (the small white one)
2. While holding the sync button press the power button to turn on the console
3. Continue to hold the sync button until the Console has booted up completely.
4. During the boot process the console should clear any failed updates, allowing you to use it normally.
Nov 18, 2010 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
Flashing
You have the lights of death, but dont fear...just get in contact with xbox they will supposedly replace it for free, because its a defect...
Got this off XBOX.com
Xbox 360: Three red lights flash on the Ring of Light View products that this article applies to. function loadTOCNode(){} Article ID : 907534 Last Review : February 22, 2008 Revision : 6.0 SYMPTOMS loadTOCNode(1, 'symptoms'); You see three lights on the Ring of Light (RoL) flash red on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue: 1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Xbox 360: The power supply light is red 906102 (http://support.microsoft.com/kb/906102/) Xbox 360: The power supply light is orange 906103 (http://support.microsoft.com/kb/906103/) Xbox 360: The power supply light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again.If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support), and then click Console Repair? in the upper-right section of the Web page.
Note The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Mar 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
