Question about Proscan 47LB45H 47 in. LCD TV
Jerky video on antenna feed of ABC network programming
I receive all Birmingham network broadcasts via my tower antenna and all broadcasts are OK except for ABC channel 40.1 HD. It turns out that this is the only broadcast that comes in at 720p. All further comments are specific to this ABC station which is the only problem I have.
Most of the local ABC broadcasts I receive (Local New, daytime SOAPS and most other broadcasts are received well on my ProScan TV, however specific primetime shows like "Grey's Anatomy", "Private Practice" and other popular primetime broadcasts result in a jerky video presentation where there are frequent brief image pauses throughout the programs.
I have another HD TV (a 32 inch Samsung) that receives the same antenna feed and it does not have this problem with the ABC primetime programming.
I've looked at all of the available menu settings and I do not see any options that might cure the problem.
Do you have any idea why I am having this problem? This ProScan TV is new and I have a couple of weeks to decide whether to return it to Sears for a trade-in or a refund, so I'd appreciate your help quickly.
Dennis Thornburgh
You didn't say so but I believe the TV you're using that having the problem is a TV that uses motion compensating frame interpolating technology... a common feature with 120hz and 240hz LCD TVs. I have one of these types of TVs and I have this issue with ABC as well. ABC has begun dropping video frames from some of their primetime shows (the ones that start at the 8e/7c time slot seem most effected) to speed up the broadcast to a point where they can get an extra commercial in. On normal TVs, including the older 60hz LCDs, this is not really noticeable. However, for the motion compensating frame interpolating technology, the TV's video processor must sync up with the 'telecine' processing (conversion from the originally filmed 24fps to broadcast 60fps) so that it can eliminate the copied frames that the telecine processing produces before it can create the interpolated frames between the original frames. When the TV's processor hits a missing frame, it loses sync and has to rejoin and causes the jerky motion you're seeing.
For a solution, you can turn off the motion compensating frame interpolation tech on your TV. Each manufacturer calls it something different but the name will have something to do with smoothing out motion like 'Smooth Motion'. In this case, you need it off for the motion to be it's smoothest (not the case with most TV though).
For a better solution, send a complaint to ABC and your local ABC affiliate.
Posted on Sep 28, 2009
My vizio is set on avor antenna I have a HD antenna but TV won't pick up my favorite network stations wtva om nbc or abc
re-orient your antenna , the more the higher the better signal reception you will receive. and check your neighbor tv reception if they are facing the same problem with your tv , the problem isnt with your tv, its the tv network sometimes failed.
Nov 29, 2016 | Vizio Televison & Video
I just bought a m221nv from ebay tv dealer an he said i could jus plug it in in my kitchen, bedrm or ? and watch it via my router cause it has wifi no need connect cable, antenna or anything but i cant get...
The wifi connection will allow you to access content via the Vizio Internet Apps (Netflix for example) but not tv broadcasts.
Your tv can access tv broadcasts (CBS, NBC, FOX, ABC) over the air but w/o an external antenna the signal and therefore the quality will probably be weak.
To access cable/direct tv/fios content you will need to connect the tv via a cable.
Mar 01, 2011 | Vizio M221NV 22 in. HDTV LCD TV
Do I need a digtal converter box to pick up local stations via antenna?
Some local broadcasting will still be in analog but this is just jor simple programming such as college stations. To get local programming such as NBC,ABC,CBS etc. you will need to get a converter since the government has mandated all broadcast be in digital to free up air space.
Note that it may be a case by case basis for some smaller areas.
Dec 29, 2010 | GE 31GT720 31" TV
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
Verizon FiOS doesn't get new digital multicast channels
Solved that problem by installing and over-the-air antenna and am in the process of firing my cable company. I will retain their internet service and go to a base package on satellite for the likes of my kids' favorite networks (Nick, Cartoon Net, Disney) and my Fox News Channel), but my programming options are already growing from 7 analog to 13 digital from off-air in recent months and another 2-5 different subchannels are likely in my market in the next 24-36 markets (for free). Why pay to watch commercials when they are free?
Dec 02, 2008 | Televison & Video
DTV connection
Have you tried This will show you the location of the HD broadcast towers for your local stations and my recommendation would be to use an outdoor antenna if you can. Picking up the reception is definitely about pointing the antenna in the direction of the towers.
Nov 10, 2008 | Televison & Video
Digital tv tuner Converter box
Your ability to receive stations will be based on the the type of antenna you have. There are three typical types: a Yagi ( It is the traditional type) it is uni directional ; bi--directional; and lastly omnidirectional. Both the Yagi and Bidirectional need to be pointed toward the local ABC affiliate tower to receive signal this may result in loss of others channels at that time. Finally all antennas have a range that they are effective. Check the range of the antenna you have. If you go to they can tell you the proper azimuth for pointing your antenna and they will give you a breakdown of the towers so you can see the specific tower you need to point toward to get ABC and if I remember correctly they give you the distance from your location to the tower.
If you have any questions post a comment to this solution. Hope this helps you.
Sep 10, 2008 | Televison & Video
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Proscan 47LB45H 47 in. LCD TV Logo
351 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
