Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Blue dots on screen
Blue dots onscreenblue dots in picture and in corners
  • 734 Answers
You have a optical block issue. Contact Sony support to see if they are still honoring the extended warranty. This can be done from the web or by phone. It's likely you will need to speak to them if the extended warranty has expired. NOTE - this is not your warranty, but a Sony accomodation for a early production issue.
Posted on Dec 12, 2008
  • futureloginn
    futureloginn Dec 12, 2008
    These issues are problems in the light engine (optics block)the dots are called "starfield" and the geometric is "roadmap"
    replacing the light engine will fix the issue. for awhile, sony was extending the warrany on the engine for these issues only, but that may have expired.
    part # A-1606-008-A
  • futureloginn
    "optimal block"---
    just found this on the sony website. here is the link. sony says they will cover the costs for the optical block including parts and labor through dec 31 2008.
    http://esupport.sony.com/perl/news-item....
    Thanks
    Master:
  • 479 Answers
Problem could be internally on the main board.either bad ic or capacititor or bad soldering at junctions.needs to be checked with a multimeter to locate the exact faulty component.
Panasonic PT-43lc14 blue dots lower left corner of screen
A problem in the optical light engine this set uses to project the picture on the screen---if right cost of repair will exceed value of set or cost of a new set.
Oct 29, 2012 | Panasonic PT-43LC14 43" Rear Projection...
I have a sony kdf50we655 TV. Over the last 12 months, the picture has been increasingly "pixelating" with royal blue dots. It started with the lower right corner of the screen fading from black...
This is not a LAMP issue, it is much more serious than that, you need to have it checked by a certified technician, it sounds like the image prossessor
Jul 27, 2011 | Sony Televison & Video
Blue dots on screen. Blue band on on/off side of screen.
blue dots on screen,bright blue haze right corner to north westpast center of screen.
May 24, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
2004 Sony KDF-55WF655 LED TV. Blue dots grouped and sparce all over the screen. Some dots appear to be twinkling. Lower corner has bright cloudy display. Dots and cloudy corner display will change state...
Bad Light Engine Call Encompass Parts Distrubtion
1-800-638-3328 or Visit their website they will list Parts in stock for this Model. UED has light engines
1-800-648-6657 you can also Look them up on Ebay sometimes you can find Parts alot cheaper their.Part number#A-1084-662-A Pice $1,423.64 core fee $800.00 Part Cost $623.64
Mar 25, 2010 | Televison & Video
Blue dots and blue area on my screen
Your blue LCD panel is failing. It is within the Optical Block and the entire block must be replaced in order to repair this. Over time (usually a short amount of time) this problem while progress until the picture is bad enough that you will want it fix immediately. So, it's good that you are looking into this now :) Here is a PN for the Optical Block... PN: A-1084-668-A I hope this helps.
Mar 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue section (corner) and blue dots
This set has no internal manual adjustments for color. The Tracking or B&W balance is accessed via the service menu. I don't suggest you attempt to adjust without instrumentation. the trouble with your set is not an adjustment. Most likely the Optics are at fault. This model has had issues with filters in the optics being destroyed over time by the lamp. The blue haze will get worse and continue to grow over the whole picture. The only option is to remove the Optics (light engine) and sent it out to be rebuilt.
Apr 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue dots on screen
Sorry I was mistaken. see this:
http://ciscdb.sel.sony.com/perl/news-item.pl?news_id=206&mdl=KDF50WE655
Looks like your model is covered till December 2008
Please be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue dots and blue color
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
Jan 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
