Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
The spary arm on my bosch dishwasher wont spin.
The spray arm on my bosch dishwasher wont spin. Water is coming in to the dishwasher and the spray arm is not obstructed in any way. I checked the filters and they are clean
  • 42 Answers
You have a failed circulation pump
Posted on Dec 21, 2008
Wont clean dishes
The little holes in the spary arms can block with general gunge etc. We use toothpicks, skewers to clear them. That sometimes helps.
Nov 16, 2011 | Dishwashers
2 MONTH OLD bosch DISWASHER. WATER WILL COME OUT BUT TOP SPRAYER ARM WONT SPIN??? LEAVING DISHES ON TOP DIRTY??? LOTS OF WATER PRESSURE THATS NOT THE PROBLEM HELP!!!!!
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 31, 2011 | Dishwashers
I have a Bosch dishwasher SGV43A03 and the bottom spray arm doesnt spin. It is free to move by hand, is clean inside and has clean nozzles. The water pump is operating the top jet and top spray arm...
Hello this means the circulation pump would need to be replaced. You can purchase the part from the link below. Also there are several articles that explain how to work on Bosch dishwashers.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
No water pressure in dishwasher
bosch shu5312uc upper spray does not spin. pours water through the center section thus not propelling the arm. any ideas? should the upper arm have any o-rings
Dec 06, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
May 19, 2009 | Dishwashers
I have a kenmore 665 dishwasher where the spary arms do not spin.
  • First, check water level. Start machine, wait until the machine begins main wash. Open the door, the water level should be just below the heater element. If too low replace inlet valve.
  • If you can't hear the wash motor running or is just humming, the motor may be bad.
  • To check if the food chopper is blocked or broken;
  1. Remove lower spray arm by holding the arm and rotating the spray arm retainer.
  2. In the back of the tub, unclip or remove the screw from the upper spray arm supply tube.
  3. Rotate the lower spray arm support to the right while disconnecting the supply tube from it.
  4. Remove the four torx screws from the sump cover, remove assembly.
  5. There may be a primary filter in the left side of the sump, if so, remove the torx screw and the filter.
  6. On the right side there is the chopper assembly cover. Remove the torx screw and cover to expose the chopper.
Hope everything goes well for you,
Regards
Richard
Feb 02, 2009 | Dishwashers
Bosch Dishwasher
the spray arms are rotated by water coming out of angled jets, this water being forced round by the main circulating pump. suspect it may a fault with this pump
Mar 23, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
737 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
