Radio Communications Logo
Posted on Dec 12, 2008
My radio powers up, shows err, then powers down
My husband likes these 2 ways, can you help?
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 14, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
332
Points
The memmory bord is either dirty or fried from use and err stands for error try asking raidio shack to fix it.
2answers
Mazda etude radio shows ERR. anyone with a fix will be appreciated
check fuse
check connections to rear of radio.
if good the Radio is inop. get it fixed.
2answers
ERR code on mazda etude radio
double posted, why do that?
and again shows 2 cars, why post 2 cars> makes
very confusing. s
Shows ERR when it is turned on
Hello, If you can't get it to work, try to do a factory reset.
Turn the unit off, then Hold the PRINT and ESC key down and then Press the power button. KEEP HOLDING THE Print and Esc key down for 2 seconds and then release both of them. You should see a message in the display INT?, Press SET to Reset your printer, or Esc to cancel.
Hope this helps.
Best wishes
Mac =)
Error message ft-530
is the radio in duplex (offset transmit freq)if keying takes radio out of band it would show err,select simplex ie transmit/recieve same freq
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
About 3 weeks ago a friend had to disconnect the battery to change the head light bulb. After reconnecting the battery, I know longer had use of the radio. If I try to turn on the radio power it states...
the radio is an anti-theft type and needs a code to reset after losing power. The code is usually in the paper-work obtained when the car was purchased. the code is 5-6 digits long and is on a plastic card with the radio serial number.
the oil life message will continue to show until it is reset. With key off, hold the trip odometer reset button down. now, while still holding it down turn the key to on but don't start. Count to 20. The oil life message should be out and reset.
tires rubbing. could be a plastic trim piece in the fender well area has come loose from when the headlight bulb was replaced. Look under there and see if you can spot where the tire is rubbing. Turn the wheel one way all the way and check, then the other way and check.
22helpful
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and...
hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
Code for radio for ford falcon 1991 shows err on the panel how do i get it off and put in the radio code which i need as well
the code is with the vin number that came with the car the radio came in - the reason u don't know the code is because 1 - u just never copied it down or 2 - the radio came from another car.
1 - try calling the local dealer with ur vin number - - then also ask for any recalls etc --
2 ask the local radio installer company like best buy - etc - - - if they can get the numbers for u
25helpful
2answers
Reset security code on AU Falcon
turn key to <acc> turn radio will blink err. leave on for at least half hour.err will be replaced by enter code.
5helpful
2answers
ICOM IC-A23 CL-ERR Problem
My neighbor just had this problem so I delved into it and fixed it.
You will need another working radio and the cloning cable.
DO NOT GO BUY ONE FOR 23 BUCKS PLUS SHIPPING!!!!!!!
This cable is nothing more than the same one you use to pipe your MP3 player into a car's AUX input.
You either have one or know someone who does that you can borrow.
If not go buy one from Sears ,Best Buy or any decent truck stop should have them for about ten bucks.
Turn both radios off.
Now with the 3.5 mm cable plugged in to both radios hold down the up and down arrow buttons and turn them on.
They should say "clone".
Now press the" ENT" on the good radio,
This will send the data over to the "bad" radio.
Now turn them both off, remove the cloning cable and turn them back on.
Both should be working now.
\WARNING if your battery is in bad shape it can cause the problem to come back. Either deep six the battery or hit the battery for a few seconds with your car battery charger to shock the cells.
Some times this can extend the battery's life.
Good luck!!
Rich
Top Maxon Radio Communications Experts
eradiostore
eradiostore
Johnny 1000
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
