Question about Jenn-Air JGC8536 Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
How do I replace the ignitor myself
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Posted on Feb 15, 2011
One of the ignitor is cracked. Do I need to replace the whole burner base?
you do not need to replace the whole burner base you need to replace de ignitor
Sep 24, 2011 | Jenn-Air JGC8536 Gas Cooktop
The stove top seems to be clicking, but the burner won't light
A common problem with that type of ignitor is that the porcelain insulator (much like a spark plug has) can crack easily. When it does, there will be a clicking sound, but the spark no longer arcs from the top of the ignitor post to the burner and cannot light the gas. Without an intact insulator, the ignitor is effectively shorting out and needs to be replaced.
Dec 27, 2010 | Jenn-Air JGC8536 Gas Cooktop
The ignitor stays on when all burners on. Usually goes off after a few minutes. 5 burner gas cooktop. Any thoughts?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 09, 2010 | Jenn-Air JGC8536 Gas Cooktop
Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Jun 21, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Two of five cooktop burners fail to light
you can try to scratch the area where it grounds to with a wire brush or screw driver this will help sometimes. sometimes when it archs down try tighten the screws to lift up the ignitors into the hole better. or if this doesn't work replace the ignitors.
Jun 07, 2009 | Jenn-Air JGC8536 Gas Cooktop
Ignitor on burner #2 keeps clicking even after burner #1 lights
Jenn Air uses a reignition system on their gas cooktops.It is very important that you have a well grounded recepticle. Please check that and please get back to me.
Sep 11, 2007 | Jenn-Air JGC8536 Gas Cooktop
How do I clean the fan asembly on a jenn air jgc8536.
it will be due to the lack of lubricant inside the fan and a part of the cylinder can be broken due to wear and tear u open that assembly and verify it if everything ok put a little grease or oil and close it
Jun 27, 2007 | Jenn-Air JGC8536 Gas Cooktop
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Nov 26, 2006 | Jenn-Air JGC8536 Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop Logo
1,263 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
