Question about Sharp Aquos LC-26P70E 26 in. LCD Television
Tv channels jump from dtv to normal tv then teletext
The channels change every i minute
2 Suggested Answers
SOURCE: 37" aquos
It sounds like it may be n demo mode. Check the inbuilt menus and check this is turned off.
Posted on Feb 28, 2008
I can not get teletext on my tv lg flat
you should press the home button of your teletext page usually its 100
or you could press one of the four colored buttons o your remote control unit so it will reset to the home page of the teletext
(a black page mostly says that teletext isn't available to the specific channel )
Aug 08, 2014 | LG 32LG30 32 in. LCD HDTV
My sharp tv keeps changing from tv to dtv teletext and all av channrls. help me fix this plz
The AV button on the remote or on the TV is stuck in the pressed position, Check buttons and see if you can free them. Too see if it's the remote or the TV , take battery out of remote ,and if the problem go's away then its in the remote.
Dec 27, 2010 | Televison & Video
Samsung Exit TTX mode
Had to reset the TV and re-tune all channels. But it worked.
Feb 02, 2010 | Samsung DynaFlat TX-P3064W 30" TV
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
CHANGE CHANNELS WITH THE CONTROL
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
TB100MW9 DTV DIGITAL TO ANALOG CONVERTER
I assume you are attempting to connect another device to the set.
Selection of the output channel is normally accomplished from the external device, not the set.
Jun 30, 2008 | Philips Magnavox 27MS343S 27" TV
37" aquos
Nov 24, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-26P70E 26 in. LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
