Question about HP Scanjet 7800 Pass-Through Scanner
Hp scanjet 7800 shows document feed empty
Also code 04 or code 08 will show on screen
  • 43 Answers
Hi
these scanner take a bit of work-open the front and then close the front- there is a latch to open the front of the scanner at the top of the front panel. this will clear the 04-08 or 24 error.
sometimes it's best to switch the scanner off and then back on which will reset the connection between the scanner and the PC
regards Liz
Posted on Feb 22, 2010
My HP 7800 creates a blank area on one side when using duplex mode
No manual, but have you checked the scanning light and plates. It could be that some material has been transferred on the to light or plate in such a way as to only effect the scanning when in duplex
Nov 25, 2012 | HP Scanjet 7800 Pass-Through Scanner
My hp scanjet 7800 does not turn on, the adapter has the green led light showing that it is getting power
First get a multimeter and check if the power is going through the adapter to the end of the cord. The AC/DC transformer should output 32V DC at the end going into the scanner. If it has power, then the scanner power switch or the unit itself has failed. If there is no power passing through the cord, then try a new adapter. (You can find some by Googling - I saw some from various vendors.) If it is the scanner itself that has failed, check if it is under warranty.
If it is under warranty, contact HP for service. They may have the power cords as well but I didn't check that far. Otherwise decide if it is worth the service charges.
I hope this helps.
(at least I do not think this scanner has a hard power switch on the side of the unit.)
Oct 04, 2011 | HP Scanjet 7800 Pass-Through Scanner
Hp scanjet 5590 failed to create empty document
HP SCANJET 5590 ERROR "failed to create empty document"
Aug 18, 2010 | HP Scanjet 5590 Flatbed Scanner
Under ''Where do you want to send the scanned image, Scan to'' list box is empty in HP Solution Center for HP scanjet G4010. You can not type a destination in the box. Does someone have a solution or...
Hi wjacks1
When you scan a picture it will be saved as a file in a directory When you scan a document, there are 2 ways to do it. You can as an image in which case it may be automatically saved in a directory with the names like scan0001, csan002 etc
If you selected the option to scan as a document then "scan to " should show few programs in the list like Microsoft document, notepad etc.
If you do everything the correct way, and still no list comes up, probably you have to reinstall the HPSolution Centre or update it from the HP website.
Good luck
luciana44
Oct 04, 2009 | HP Office Equipment & Supplies
At scaning time show
Hi
I take it the scanner is connecting to your pc okay? the paper need to engage in the feeder. Try just putting one piece of a4 copy paper in the scanner and seeing if that will register as beng paper in the document feeder.
Kind regards Liz
Feb 19, 2009 | HP Scanjet 7800 Pass-Through Scanner
HP Scanjet 5590 scans inmage on other side of paper on ADF Ok on flat bed
Really strange! May be the brightness is not controlled in the ADF mode, too bright to scan data on the backside also. Try reinstallig the software.
S. Mohan
Aug 18, 2008 | HP Scanjet 5590 Flatbed Scanner
Feeder
Hi
the scanner will do that sometimes, it's easiest to just feed the pieces through one by one when that happens.
Regards Liz
Jul 03, 2008 | HP Scanjet 7800 Pass-Through Scanner
Hp scanjet 7650 urgent issue...
just reinstall scanner driver and software
Mar 20, 2008 | HP ScanJet 7650 Flatbed Scanner
HP Scanjet 7800 Pass-Through Scanner Logo
755 people viewed this question
Ben Johnson
