Question about Epson TM-T88III Thermal Printer
Epson t88iii will not print
I have just installed a epson tm t88iii with updated drivers but the printer uses a paralell cable and I do not think it is comunicating on lpt1 .The previous printer was a zonerich which used a usb connection, do Ineed to tell the computer to use the lpt1 port. if so how do I do it.
many thanks
  • Anonymous Mar 19, 2014
    Can someone tell me how to reset the printer to default settings
I would like to say sorry to you I got my serial port mixed up with the parallel port. I have resolved the problem, it was a DIP switch change which needed to be set. If anybody can not get their computer to communicate with the printer then I would suggest they download the Epson Technical reference guide and read it thoroughly, but only use the guides for your method of connection which is dependent on your model of printer. I found that for a baud rate of 38400 DIP switch SW 1 numbers 7 & 8 should be switched to ON .I hope this helps some else.
Posted on Dec 14, 2008
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
I am unable to print with the printer TM-T88 III. the status of this printer is 'Not Available'. OS is Xp , and i install the driver APD_412.e. Please advice, george
Your printer is probably set to Off Line. You'll need to go to Start-Printers and Faxes, and in the new window right-click the Epson TM-T88III icon and from the popup menu select the Use Printer Online setting.
If this doesnt work check to see if the USB cable is loose both at the PC end and at the printer end. While you're at it, see if the printer shows any signs of life (any lights on, any messages on the LCD)? There just may be an issue of loose power cable, so you may want to check that also.
Jan 14, 2011 | Epson TM-T88III Thermal Printer
I have a Epson TM-T88III as a networked receipt printer, we have a new machine that has windows 7 and I can not get a driver to install that works. Any suggestions?
Dear Clark, it seems you have a lot of money when you suggest to waste a printer 240€ value.
The solution:
Link www.epson-pos.com and register, after that, follow this path:
Thermal line printers
Choose your model
Epson Advanced Printer Driver for TM Series (the first option for Windows7)
Install it, it Works properly.
Jun 29, 2010 | Epson TM-T88III (C420863)
How do I get the cash drawer to pop using the Epson TM-T88III and windows driver? I am currently using RMS as our point of sale system but do not want to use OPOS drivers as this printer and cash drawer is...
You can set this up under printer settings - Under Windows XP - At the control panel, click printers, right click the tm-t88iii printer and select properties. Click the 'Device Settings' tab and there *should* be a option to open the cash drawer after printing.
Nov 06, 2009 | Epson TM-T88III (C420863)
EPSON TM-T88iii printer 'Not Available'
I've had this issue many times. The only resolution is to completely uninstall the printer using the epson utility then re-install. This solution is only temporary as it will go to unavailable within 2 or 3 days.
Apr 09, 2009 | Epson TM-T88III Thermal Printer
Do not suceed to print with usb-to-serial cable
use a null cable and is ok.
Diego.
compuzonic.com
Jan 18, 2009 | Epson TM-T88III (C420863)
Can't install epson tm-t88iii serial
unistall the epson driver.
reboot your system.
connect and turn on the printer.
reinstall the driver, v3.02, selecting for create a serial port.
choose the right setting os serial interface.
after install, reboot your system.
it works to me.
Aug 19, 2008 | Epson TM-T88III Thermal Printer
Epson TM-T88III - Always showing as not avaliable
I had the same with XP .... I had my home inkjet (Parallel port) on LPT1. The Epson TM software and printer worked fine after removing the ink jet from LPT1 and re-installing the TM driver.
May 08, 2008 | Epson TM-T88III Thermal Printer
Epson TM-T88III Thermal Printer Logo
697 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
