Question about Bemis Cool Mist 336 500 Humidifier
Could you direct me to instructions on disassembling the Bemis 500 humidifier so I can clean it, specifically the fan?
I found your web site to be an essentially useless waste of my time, and was not surprised at all when you offered to sell me something, rather than addressing the problem.
Please stay out of my mailbox; Bemis is on my list of "Do Not Buy" products. Maybe others are as bad, but at least I can give them a try. I already know you guys are are useless sales pitch.
Posted on Dec 13, 2008
When I turn on the unit, it humms and the fan doesn't turn. Help.
If you can easily get to motor I would unplug unit and check motor to see if it turns freely. If it does I would plug the unit back in and see if the humming noise is coming from motor. Ifyou decide that the motor is the source of the noise and you can do so safely spin the fan and see if it will try to run, If it does I would unplug unit and give fan motor and blades a thorough cleaning. Clean any hair,lint or dust from aaround motor shaft. A small motor like these does not take much to slow or stop them. Plug it back in and try it. If it stiil does not work I would replace the motor. Hope this helps. Thanks
Nov 19, 2010 | Bemis 697 400 Humidifier
Fan does not run. What now? Unit has been cleaned, not used since last winter. When I turn on the fan, it does not start - at any setting. Is there a fuse somewhere? Manual which came with humidifier is...
Not sure what solved the problem: Took fan section control box apart, used compressed air to blow out both areas. Noticed that on/off switch did not stay stable, but was able to re attach knob. By wiggling connections and plug-in, it did finally start.
Jan 08, 2010 | Bemis 427 3002 Humidifier
Broken fan blade on the 697400 humidifier
Hay Richard -- Little suckers spin to fast for gluing. Take the fan blade off , mark one side before you remove it ex: put an x on the side that is facing the wall. Take blade to a Johnstone supply house. Should be one near you somewhere, they are national. The guys there are usually very good at matching up fan blades. Make sure you keep the one you have with the mark on it. When you get home install the new blade the with the side out that was on the old blade. Hope that helps
Mar 05, 2009 | Bemis 697 400 Humidifier
Fill level & digital readout (bemis humidifier)
There is a sticker that comes in the owner's manual that apparently falls out frequently. I was told that the fill level is two inches below the top edge of the reservoir. I am going to mark mine with a Sharpie since stickers have a tendency to fall of when wet.
Jan 05, 2009 | Bemis Whole House Digital Humidifier ED11...
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Moisture not coming out
i realize this answer is a year old; but, i would guess you didn't let the wick become saturated before running. fill the resevoir with water, then let the humidifier sit idle while the wick is saturating. when it is completely saturated, the refill light will go off. refill the resevoir with additional water, as needed. then you can run the humidifier.
Jan 20, 2008 | Bemis Whole House Digital Humidifier ED11...
Bemis Cool Mist 336 500 Humidifier Logo
98 people viewed this question
Top Bemis Humidifiers Experts
Paul Carew
Dennis
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
